PDA
View Full Version : 2000 cavalier help needed
ZrexC
03-02-2008, 09:29 PM
ok it overheated, and theres like 4 bolts directly in front of the valve cover, the alternator bracket bolts to 2 of them. anyways there was water squirting out of 2 of them so i tightened them down and the water stopped leaking. however it wont start, it turns over and hits some but wont fire up. also when it overheated the passenger side floorboard was soaked. anyideas. also id like to know where the headbolts are located.....lmk....thanx
Indyvette
03-02-2008, 09:57 PM
Sounds like you may have flooded your engine... i'm no good with caveliers though, so i wouldnt know where they are located lol
Bowtiemontecarlo
03-02-2008, 11:01 PM
if it soaked the pasenger side florr board u got a heater core busted .My guess it overheated and blew the lines .
Sneakin Deacon
03-03-2008, 02:54 AM
....do what?
ZrexC
03-03-2008, 06:24 AM
thats what i was thinkin...thanx
ZrexC
03-03-2008, 06:26 AM
....do what?
yeeaahh....lol
ZrexC
03-03-2008, 08:42 AM
anyone know what all you gotta take out to get to the heater hoses?
Indyvette
03-03-2008, 05:06 PM
I guess i dont know what i'm talking about lol, it just sounded like you may have flooded the engine (which is a void answer now)... but i have experienced similar to what happened to your car, but mine was an AC leak.. under the glove compartment, the floorboard was wet..
ZrexC
03-03-2008, 07:05 PM
the heater core is a bitch to get to!
Indyvette
03-03-2008, 07:14 PM
haha, i'd expect so.. we have diagnosed my car's fuse problem... the wiring is shorting out, so any fuse we put in blows! =X
Mars_302
03-04-2008, 02:09 PM
thos heater cores are easy, wtf you talking about. Sounds like to me you blew the headgasket. Those 2.2 OHC blow easily if overheated
ZrexC
03-05-2008, 09:38 PM
yeah easy after you take all the fawkin b.s. outta the way... headgasket aint blown
Sneakin Deacon
03-05-2008, 11:32 PM
done a compression check? hot and cold?
ZrexC
03-11-2008, 05:54 PM
a fawkin fuse was keepin it from runnin...head gasket is blow lol
slowfire99
03-11-2008, 06:14 PM
ill give you 200 for it ? check the head to see if its warped . remember its aluminum !!!
ZrexC
03-16-2008, 12:02 AM
its 1000 miles from tampa
slowfire99
03-20-2008, 02:13 PM
ok were is it ? i thought it was in seffner ? if its cheap enough its worth driving .
swenson13x
03-21-2008, 02:13 PM
If ur looking for cavalier motor parts ill sell mine to ya. mine isnt OHC tho but the head is ported.
