PDA
View Full Version : What guns do you guys use?
351coupe
02-27-2008, 12:57 AM
What do some of you guys use,not as far as brand,but model?I was told an HVLP gun works best for matalics,and a RP is better for clears.Give me an idea of what you guys use for primer guns,I was told non HVLP for primer and use a cheap gun,used a cheap gun,and won't do that shit again.I did use a good deville biss for base/clear though,just practicing for now and I'll post up pics of my first painted fender tomorrow to see what you guys think.Anyway,I want to buy a Sata primer gun and a Sata clear gun,and recomendations on model?Thanks for any advice/direction on this.
Darrell
02-27-2008, 07:48 AM
Sata NR2000 HVLP 1.4 tip for sealers and base
Sate RP Digital 1.3 tip for clears
Cheap $80 throw away 1.5 tip for primer
351coupe
02-27-2008, 08:40 PM
Thanks Darrel.
Krucial Kolors
02-27-2008, 09:56 PM
all Sata
Nr3000 hvlp 1.3 for sealer and base
nr 3000rp 1.3 for clear
hvlp klc 1.7 tip( I know it's a cannon)
351coupe
02-27-2008, 10:11 PM
I tried looking on Sata's web site,but that shit's all in German.Anyway,what's the difference in the #'s?3000 2000?I think I've decided on the SATAjet 100 B for my primer gun,but I'm not sure to get the RP or the HVLP,any differances in spraying primer with an hvlp opposed to rp?
Krucial Kolors
02-28-2008, 08:21 AM
Hvlp is way less over spray and transfer rating is higher. The jet b is good just alot of over spray. The klc is very versatile. I use it to cut in parts base and clear, Spray my boat with gelcoat, and primer with very low over spray. What you looking to spend? I usually rotate all my guns when the new version comes out. might be getting rid of mine
the difference between the 2000 and 3000 is the shape and a little better wider spay pattern. My 2000's didn't have the quick connect cup and the 300 do.
this is English Sata usa website
SATA.com - Home (http://www.sata.com/home.jsp)
351coupe
02-28-2008, 09:06 PM
Thanks alot for the info man,I really appreciate it.I also appreciate the offer on the klc,but I kinda want to buy new ones for myself if you can understand.
Krucial Kolors
02-28-2008, 09:31 PM
100% understand. Keep us posted and see how you like it.
