View Full Version : question about alternators
1stGen7
02-24-2008, 10:12 PM
i want to know if it would be better to run the stock alt for chargeing the cranking batt and then a 300 amp alt for the system batts? or could i just run 1 300 amp to replace the stock alt? i will be running 6 - 8 deep cell batts in the bed
Notladstyle
02-24-2008, 10:45 PM
the stock alt is all you will ever need... even if you hooked up 12 fleamarket subs to 9 walmart amps, I doubt your lights would dim.
1stGen7
02-25-2008, 12:33 AM
im doing 6 or 8 RE SR series 12's and 6 or 8 amps to push them i might just do 2 per amp insted of 1 per amp and do 3 - 4 amps for bass
the727kid
02-25-2008, 08:43 AM
Run a seperate alt, just for the audio that charges at 17volts. Then you will only need one amp for the all the subs, easier to install and what not.
Notladstyle
02-25-2008, 12:53 PM
Why stop at 17? Install a 40volt alternator and then you can just use straight current from the alt to drive all your subs and cut out the middle guy!
galacticmonkey
02-26-2008, 03:23 PM
Just do 8 sealed 12s with a nice 2,500rms amp.
Phil...this is what you should do...
http://blueghost.org/db3/00277/blueghost.org/_uimages/6altAir-PowerBracket.jpg
NT_Hardcore
02-28-2008, 10:24 AM
why the hell do u need 6-8 batts? maybe im missing something here...
Paul's idea is the best. Just get a seperate motor just to drive your stereo.
Lets see, how many horsepower equals watts?
conversion please!:
1 horsepower = 745.699872 watts
Now lets do a simple cheap honda engine at 100ish HP
wowzers
74569.9872 watts!
74 kilowatts bitch!
Of course it isn't a direct conversion, as there are losses out the asshole everywhere, but it gives you the basic idea that if you had a dual-motored, completely superpowered car audio setup, you could run about 1000 walmart Lightning Audio subwoofers. You might get up to 148 DB!
I've driven 6 1000.1 JL amps (6000 watts total) on 6 Memphis 15" subs in the bed of a pickup (pass through port) off of two optima gell cells and dual stinger 160 amp alternators with 0 ga wiring throughout. He has 8000k HID headlamps and foglamps, train horns/compressor, nav tv and flip down, etc. System voltage stayed at 12.9 volts under heaviest load at idle and 13.6 volts full load driving average. I highly doubt you would ever need anything more than that for the setup you are referencing. Again, maybe I am missing something?
the727kid
03-06-2008, 12:50 AM
^^^JL Amps are major current hogs, fuck em lol.
Content Relevant URLs by
vBSEO 3.2.0 RC5
