PDA
View Full Version : Cosworth EVO IX Cams MIVEC (272)
kantfadedisazn
02-14-2008, 02:44 PM
Cosworth Camshaft Set 272 M2 Grind Mitsubishi EVO IX MIVEC 4G63 05-07Model: KK3921 price: $639.99
Cosworth has been engineering camshafts for nearly 50 years. That coupled with years of innovative multi valve cylinder head design ensures our camshaft designs are the most efficient in providing maximum usable power across the widest power band. Each cam is ground from a new billet and finished using the same procedures we use in our extreme level race engines. Cosworth camshafts are the perfect compliment to our CNC Ported Big Valve Cylinder heads. Our cams are profiled to increase boost response thereby increasing engine torque and power and are fully compatible with our CNC Ported Big Valve Cylinder Heads.
Specs:
- For use with Evo IX Mivec cylinder head
- Intake duration "272" deg
- Intake lift 11mm
- Exhaust duration "272" deg
- Exhaust lift 11mm
- Excellent torque and boost response
- Broad power band
- Compatible with OE valve springs if factory rev limiter is in place
- For maximum high rpm performance use Cosworth upgraded valve springs.
kantfadedisazn
02-16-2008, 08:45 PM
get your cosworth cams today
kantfadedisazn
02-27-2008, 01:24 PM
