'93hatchCrustang
01-28-2008, 10:59 PM
just have general questions about my set up
i have a '93 hatch 4 cylinder that is not that exciting so i did some research and found out about the old turbocoupes and svo's etc...
well ive been slowely piecing together my setup right now i have a turbo coupe motor minus turbo and turbo manifold also a T3 and factory top mount and the turbo coupe fuel injectors, and large vane sensor
the block is in "fair" condition so in your guys experience should i replace the bearings and rods and rings? i plan to have it tanked and cleaned up, also i want to have the uper and lower intake manifold ported if any one has done this the easiest way to do this. also other setups that you have used i know the easiest way to get power is flow in and out of the motor plus upping the boost(i.e) manual boost controller, well all feedback is helpful
