PDA
View Full Version : where is the damn door dinger on a 1999 neon
rollin420a
01-23-2008, 02:40 PM
where is the damn door dinger at so i can snip the wires its pissin me off :mad:
Dano Moparo
01-23-2008, 04:17 PM
The seat belt reminder system uses both visual and audible signals. A combined seat belt and key reminder chime with a red light on the instrument panel.
The system will always illuminate the seat belt reminder lamp for four to eight seconds when the ignition switch is turned to the ON position. The CHIME will sound during the same time interval if the driver's seat belt is not fastened. Passenger belts are not connected to the system. The chime will activate if the drivers door is opened and:
The key is in the ignition switch, with the ignition switch in either the OFF or accessory (ACC) position
The head lamps are ON.The chime is part of the instrument cluster
CLUSTER WIRING - HARNESS CONNECTORS
J1 CONNECTOR J2 CONNECTOR PIN DESCRIPTION PIN DESCRIPTION 1 DOOR AJAR 1 OIL PRESSURE 2 HI BEAM 2 ABS 3 RIGHT TURN 3 MIL * (SERVICE ENGINE SOON) 4 SEAT BELT 4 ENGINE TEMPERATURE 5 IGNITION FEED 5 KEY IN / HEADLAMPS ON 6 BATTERY 6 BRAKE 7 TACHOMETER SIGNAL 7 CHARGING SYSTEM 8 GROUND 8 LEFT TURN 9 AIRBAG 9 ILLUMINATION 10 SPEED SIGNAL 10 FUEL LEVEL
rollin420a
01-23-2008, 04:40 PM
thank you for tht but i just took the pin out on the door jamb and disconnected it much better no headache and i still have dome lamp
