Differential question
Old Jan 14, 2008 | 02:56 AM
SmokinS13SR20's Avatar
That ginger...
Default Differential question
I've been checking out spools for the hell of it and read that a mini/full spool can't be used in a casing that is a factory clutch type lsd.
Is this true?
If so, what can be used, only that factory unit?
Old Jan 14, 2008 | 03:37 AM
GNs-r-slow's Avatar
Bondsman
Not trying to change your mind but if this is going to be used in a street application, THEY SUCK!!! Good for a track car but for street way to harsh.
If you have the extra clutches installed in the LSD youll wont have any issues for a fairly stout build.Sorry couldnt answer you ? thought Id throw that at ya
Old Jan 14, 2008 | 03:43 AM
That ginger...
Hehe, I knew this would come up. I was looking around for a buddy with an open differential. I was just curious, I do have the clutch which will be rebuilt and I'll be using.
Old Jan 14, 2008 | 03:56 AM
GNs-r-slow's Avatar
Bondsman
as long as your not doing burnouts around the corner on a daily basis clutch is the waay to go! I had 400ish in another car left 2 black marks everytime. I done a mini spool in my 65 the seen alot of street use and Ill never do that again, PITA.
Old Jan 14, 2008 | 05:32 AM
91Notch's Avatar
Is workin on his car
What type of rear end is this going into. Is this the same topic thread you have over in another forum. If so you ask about IRS so I am assuming its a Ford 8.8 IRS from a cobra maybe?
Old Jan 14, 2008 | 06:32 PM
That ginger...
The two topics are related.
The mini spool is going into a GM 7.5" 10-bolt rearend. I referred to the IRS because he is kind of wanting to go to one for camber adjustability with a air-bag set-up.
