PDA
View Full Version : subs cutting out
iamedelmann
01-12-2008, 04:07 PM
I have 2 alpine subs that keep cutting off. I got the system installed at sound advice and they suck. He's saying he's not sure what the problem is bla bla. ive had the system almost a year and it just started doing this. when it gets turned up the cut off when its down low theyre on. any ideas?
the727kid
01-12-2008, 05:09 PM
Loose ground?
iamedelmann
01-12-2008, 06:33 PM
nope the grounds good he put a bigger ground on the battery to the body and double checked the amps ground. im bringing it back to them but going back and fourth is getting old i want some ideas since im not really getting anywhere
TJElite
01-12-2008, 09:03 PM
Check your connection at the battery, and the fuse / fuse holder. In the last year or so, I have seen at least 3 fuse holders that were melted and falling apart. Seems to effect the set screw style more. Looks like they work loose, which ups the resistance, and the heat.
I also had one guy come in...local shop had rewired the amps and sold him a new deck...still had the same problem. Battery terminal was finger tight.
Toby
