View Full Version : BMW 540i 6-speed clutch issue
Teggy_Boy
01-08-2008, 04:25 PM
Hey everybody I went on a trip to Las Vegas and lent my bimmer to my father for the week, I get back and jump in the car, press the clutch and it's super stiff and has a much shorter pedal travel. I push the clutch to the floor and go to shift into reverse and it grinds, so obviously the clutch isn't doing it's job. Anyone have any suggestions? I think it's just burnt out, but before I spend 2g's (or more) on having it replaced I'd like to hear other opinions.
pressuredsol
01-08-2008, 08:42 PM
Check the fluid to verify the system is not leaking. Also check the slave, it might need to be replaced.
Teggy_Boy
01-10-2008, 03:39 AM
Thanks bud, will do. Where is the clutch fluid reservoir located? I figured it would be by the brake booster under the drivers side a/c filter, but I saw no clutch reservoir.
pressuredsol
01-11-2008, 10:33 AM
What year of 540?
jriggs
01-12-2008, 09:33 PM
you might need to have the clutch adjusted to make sure its fully engaged
I forget on 540's but some euro cars draw the clutch fluid directly from the brake mater cylinder resevoir.
91Notch
01-14-2008, 10:20 AM
From what I can see from the manual your correct that it comes striaght from the brake master cylinder but then again he never said what year it is.
But I had a problem like this in an Accord I had in my shop one time. I could of sworn to god the clutch was shot. We decided the replace the slave cylinder first and it fixed it and never came back. So I would look there.
Teggy_Boy
01-15-2008, 08:11 PM
Thanks guys! Sorry I haven't checked up on this thread. The clutch is infact "fried" and is currently being replaced along with the flywheel. I do appreciate everyone taking their time to answer my question.
2fast4ass
05-09-2008, 11:45 AM
Floridagerman.com check it out looks like you clutch cylinder has gone bad !! i may be wrong but there are a lot of 540 enthuslasts on the forum
Content Relevant URLs by
vBSEO 3.2.0 RC5
