View Full Version : need sum1 to heat springs..
clipse235
01-04-2008, 12:06 AM
i need sum1 2 heat my springs 2 make my car lower.... any1?
killerMikeD
01-04-2008, 12:25 AM
No thats ghetto! ur shit is gonna bounce like a focking slinky on a dirt road, not to mention its unsafe, changes your spring rates, and anneals the Spring steel making it hard and brittle and they will fail, and brake and you will be stuck on the side of the road ;)
KustomKonceptz
01-04-2008, 02:29 AM
Yeah, please for the sake of everyone else on the road, don't even consider doing this. You'd be better off with some $80 coilover springs from eBay....and thats not too great either.
clipse235
01-04-2008, 11:26 AM
got coilovers! thnks
Hellfire_Studios
01-04-2008, 08:13 PM
go ahead and heat them up....its the best way to do it.
::thumbsup::
Josh
killerMikeD
01-04-2008, 09:59 PM
As in you got coil overs instead of heating your stock springs right?
clipse235
01-05-2008, 12:24 AM
yep
Bowtiemontecarlo
01-09-2008, 07:49 AM
Could'nt u cut them ?
Bowtiemontecarlo
01-09-2008, 07:50 AM
could'nt u cut the springs to make them shorter ?or is that unsafe too ?
Hellfire_Studios
01-09-2008, 08:44 AM
better to cut them than to heat them....but still ghetto.
Josh
No, and if youve ever studied suspension geometry youd see that even lowering most cars has a negative effect on handling and ride quality.
SpottedMango
01-10-2008, 10:34 AM
Exactly what I would have said!
Josh
quiksilvia
01-13-2008, 12:40 AM
I :dunno:how lowering a car will decrease handling?????
ride - yes due to a stiffer spring.
A stiffer spring that lowers the car= Improved downforce
and handling around corners due to lack of roll.
Ive seen a spring heated to lower the car. They lowerd the car like .5 inch
went for a lunch brake and saw the car on the ground + plus it makes the
spring brittle
Cutting a spring will change the spring rate and give it a shitty ride, and not only that its also dangerous too.
both are very ghetto
save your mony and get a eibach prokit
Content Relevant URLs by
vBSEO 3.2.0 RC5
