PDA
View Full Version : amplifier problem
fats73
01-03-2008, 07:01 PM
i got a infinity 4 channel amp and it keeps clicking on and off from power to protect any one know why is the amp bad need better ground or what that u in advance rep will be given
the727kid
01-03-2008, 07:12 PM
Well if you think you need a better ground, then you probally do... so go ahead and try that. Secondly what is the ohm load at the amp? Is the amp bridged? Most likely it is one of those two issues.
fats73
01-04-2008, 06:31 PM
well its the one that match the infinity highs it work then just stopped and also qwhen it clicks off and on so does my headlight and dash and dome light
MCOR
01-08-2008, 10:25 PM
Nice little wiring problem. Start by disconnecting the amp and seeing if the factory lights still cycle intermittantly. If they only do it with the amp hooked up, make sure you have a good ground first, good power connection at the fuse and battery (usually a battery terminal that has loosened up), then start disconnecting stuff until the problem is gone. Again, sounds like power/battery terminal or something.
