GM Maf into DSM
Old Jan 3, 2008 | 11:58 AM
4g63T's Avatar
Default GM Maf into DSM
does any1 have experience with swapping a GM maf into a dsm. i just bought a 3inch gm maf, and a g2 translator pro. how useful will this device be when i upgrade my turbo. is it pretty flexible as far as tuning? i also wanted to use the gm maf as a blow through. should i mount it between the BOV and the throttle body?thanks.
Old Jan 3, 2008 | 12:49 PM
sheldon's Avatar
If your looking for upwards of 450whp then it will be very usefull. As a 2g maf will max out about that. Tunability depends on how savy you are and the tools you have to tune...ie, wideband, pocket logger, etc. I know that there is a 2g that uses one and is running low 10's and said is looking to dip into the single digits. And yes you should mount it between your BOV and throttle body.
Old Jan 3, 2008 | 12:57 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
i dont see the point. by the time you will be maxing out your stock maf, you should at least have dsmlink. if you have dsmlink, you have no use for the gm maf. the only good it would really do is for blow thru i would think.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Jan 3, 2008 | 01:24 PM
Flaco_GST's Avatar
Master of the cut-off T'S
Well I kept having problems with my stock maf so I bought on and It works great. It gets tuned with the gm maft then it gets fine tuned with the safcII. Never had a problem with it.
...Only god can judge me...
"If you don't set goals for yourself, you are
doomed to work to achieve the goals of
someone else."
Women might be able to fake orgasms but us men can fake a whole relationship.
V-TEC = Virtually-Torqueless Economic Cars
(PROG) Crew member #5
{o,o}
|)__)
O RLY?
Old Jan 3, 2008 | 01:25 PM
sheldon's Avatar
Everyone is different
Not everyone wants a link
Not at all....you can still utilize your stock ecu....as well as use it to tune with like an afc
Old Jan 3, 2008 | 02:58 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
well if you have a gm maft and safc, your tuning setup is pretty limited. by the time you spend a bunch of money getting that setup, you could have bought link.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Jan 3, 2008 | 05:34 PM
sheldon's Avatar
exactly....you are definately limited to only tricking the ecu to see more or less air...and if you are planning on buying both then i would deffinately invest in a link.
Old Jan 3, 2008 | 09:59 PM
KustomKonceptz's Avatar
Just make sure you have a logger and a wideband. I have experience with this setup, and since you have nothing to account for timing, you had better watch your knock and other engine vitals. It's also a tempermental system when it comes to weather changes etc., and it always seems to need some fine tuning. Other than that, I'd say it's a descent setup but you'll want link in the future.
Old Jan 4, 2008 | 04:41 AM
Flaco_GST's Avatar
Very true but the safcII was a gift so I bought the gm maft. And I also have a wideband but your right, a link would probably be better.
KustomKonceptz
"Just make sure you have a logger and a wideband. I have experience with this setup, and since you have nothing to account for timing, you had better watch your knock and other engine vitals. It's also a tempermental system when it comes to weather changes etc., and it always seems to need some fine tuning. Other than that, I'd say it's a descent setup but you'll want link in the future."
Your def right on that, weather had a big part to do with it.
someone else."
{o,o}
|)__)
O RLY?
Old Jan 4, 2008 | 12:48 PM
GsT Racer's Avatar
back in a 4g63
gm-maft and safcII are a perfect combo.... if you are a CHUMP just kidding
but I have dsmlink (shh...) and gm-maft(shhhh...), and it works wonderfully. What I love about the gm-maft as a blow-through is the fact that it reads the air AFTER everything else, such as pressure drops, boost leaks, and temp changes from going through the FMIC and all the piping. Thats what my goal was. I've been in cars that still had dsmlink with a stock MAS and they are still not as smooth as one with a gm-maft. excellent innovation.
