View Full Version : Installed Coilover,but Have A Problem
civic ferio99
12-29-2007, 07:15 PM
so lowered the civic today with coilover,ran into a few problems,but got that taking care off.but n.e ways back to my problem i have the back all the way down but i still have 1 finger between fender and tire,so whats wrong with that picture????can anybody guide me to the right direction.the coilovers r from ebay(i know i know)......thanks
i have a family to take care of so had to go cheap with suspension...
im a tuner with a limited budget.....
jlude90
12-29-2007, 07:29 PM
you bought shitty springs, thats the problem
if you want more drop just take the adjustable part out and run the spring, or just save your money, sell the ebay shit and put your stockers back on before you blow your stock shocks i'm assuming you're still on, and get some good drop springs and some good shocks
ATI LUDE
12-30-2007, 02:12 AM
Sound advice...It is better to wait a little longer and save that extra coin to get top of the line product then no-name crap 99% of the time. My guess is that you have learned your lesson now as we all have.
civic ferio99
12-30-2007, 10:22 AM
yes indeed
Outkasted24
01-05-2008, 09:39 AM
Did you use the rubber or aluminum top hat that came with the coilover setup?
If so, either take it out or reinstall it sitting above the shock set washer, That should fix your problem.
clipse235
02-05-2008, 10:37 AM
ay wen u put on the coilovers did u have to put in new struts? or did u jus put the coils on?
02-09-2008, 01:25 AM
Any shock where the coil spring fits "over" the shock is a coilover.
Adjustable coilovers allow you to adjust the ride height.
You might run the adjusters up and that will raise the body for more tire clearance. If you want the tires to clear..............
If you want to bring it by, I can show you how to fix it.
no charge.-Bob
You will probably need a camber kit to keep your tires from
being eaten, and probably re-aligned.
Outkasted24
02-20-2008, 05:32 PM
:roll:
And that has what to do with this guy's problem? :nono:
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
