Chassis & Suspension Tech Cages, braces, suspension set up and more
Need Help On Suspension.....
Old Dec 27, 2007 | 01:44 PM
civic ferio99's Avatar
I STAY KRUNCHY
Question Need Help On Suspension.....
hey peeps got some coilovers from e-bay(i know i know),so i was wondering if anybody got DIY to help me put them on. 1 for civic and 91' integ 4door....
thanks
I ROCK SEDAN!
CREW #3
Old Dec 28, 2007 | 05:32 PM
All shocks that have the coil spring over/around the shock are coilovers.
If you are speaking of adjustable coilovers, where the height can be run up or down, if the spring is still on them, install them in the same order that the old ones come off, and adjust the height accordingly. As the car goes up/down the toe and castor/camber will change, so when you get it to the height you want, the suspension will need aligning.
If you have coilover shocks of either type, and plan to install your current springs on them, you may need a spring compressor. I'm booked up solid until Sunday after 2pm. If you bring over what you have, we can install the springs on the coilovers pretty quick and you can put them back on the car yourself. pm me.-Bob
