T/S #25
12-24-2007, 07:34 AM
There is a class that they are trying to get started down at Immokalee called Street Race. They will be running the class this Saturday(29th). For all you guys that can't compete in the Stock Suspension class, come on out, this is the class for you. If they get a good turn-out, they will run this class monthly next year, just like the rest of their heads-up classes. Finally someone is trying to start a class where the average guy is going to have a chance at going some rounds. Keith from Sunshine will be keeping an eye on how this weekend turns out. If it's good, he will consider running this class at Sunshine's Heads-Up Madness events next year as well. Come out and show your support.
The rules are as follows:
Gasoline only : No Nitro, No Allky
SB 76MM Turbo : 3100
SB F1/1-X trim or = : 3100
SB Single Stage Plate Nitrous : 3100
SB N/A : 2800
BB N/A : Conventional Heads ONLY no Big Chief : 3100
No Roots Blowers
P275/60 MT Drag Radial
28 X 12.50 ET Street
28 X 10.5 Slick
Front Coil Over OK
Stock Type Rear Suspension :
Split mono or multi leaf ok - no Half Leaf/Coil Over
Torque Arms on 3rd & 4th gen F body ok
Factory Length Torque Arm on GNX ok
Rear Control arm mounting points + or - 1 inch
Slapper Bars/Cal Trac/Smith Trax/Slide-a-links ok
Mufflers required
Lexan OK
Factory Style Dash
Fiberglass Allowed : Hood, Rear Deck Lid, FR/RR Bumpers
NO Wheelie Bars
Cars/trucks must be STREET APPEARING
If you have two nos systems remove the 2nd kit prior to getting to the track.
BB combos are N/A, if you are found to have a power adder on your BB combo you will be DQ'd
SB N/A : 2800
No Roots Blowers
28 X 10.5 Slick
Front Coil Over OK
Mufflers required
Lexan OK
Factory Style Dash
NO Wheelie Bars
