View Full Version : tell me if this is normal?!?
jstarr
12-18-2007, 07:42 AM
I have a 90 fox body and when im driving at like 120 or even once i pass 100 my hurst shifter starts to shake due to the road. Its not like a major shake its more like a shimmy... it just like vibrates to the road. you can kinda see it move if you look at it... is that normal cause i asked one guy out here and he said its cause my tranny is about to fall off... i just wanted ya'lls advice.....
Steve B
12-18-2007, 07:48 AM
it shouldn't shake like you describe
jstarr
12-18-2007, 07:50 AM
so what do i do to fix it?
.Seth.
12-18-2007, 08:23 AM
O man! Thats major!
You should jus give me ur car and ill rebuilt it I guess lol
Ill give ya my 300zx
jstarr
12-18-2007, 08:25 AM
thats funny cause b4 i bought my fox i wanted a 300zx... thats funny u mention that
SleepingB18
12-18-2007, 08:31 AM
Arent there some rubber mounts that are on the trans? maybe they are just worn out??
jstarr
12-18-2007, 08:34 AM
idk.. my car is lowered and i cant get my jack under there to lift it without scratching the paint, SO i cant get under there to look i would hate to get a flat cause then im screwed!..i wish i knew what was wrong so that way i could just fix it..
topher469
12-18-2007, 09:09 AM
There are many reasons that could be going on and none of them are normal. I would go through it all and check it all. (driveshaft, flywheel, clutch) Mounts being bad you would notice it even around town high rpm, check the balancer on the front of crank. If its only going that fast is does it then it could be a wheel balance?? Many many reasons good luck on finding the cause.
My 95 did the same thing and my balancer was comming apart. G/L let us know what you find!
mx-4u2nv
12-18-2007, 12:26 PM
I had a problem like you are describing and It was due to the driveshaft being out of wack. I bought a used one from FBP for 20.00 and solved allot of frustrations...
Content Relevant URLs by
vBSEO 3.2.0 RC5
