PDA
View Full Version : quick headunit installation question
kober
12-16-2007, 05:00 PM
ok i took out my old stock headunit on my 95 240sx.. and i did everything right so far but now i dont know what to do.. the power wire is different from the car.. it wont connect.. on my previous 92 240 the power wire match perfectly.. heres a pic if u dont understand what i am talking about
this is from the car... (2 things)
http://img.photobucket.com/albums/v147/kober/IMG00233.jpg
and this is from my alpine headunit (1 hole)
http://img.photobucket.com/albums/v147/kober/IMG00231.jpg
any ideas what to do? i am sorta a newb.. so i duno
thanks. and rep will be giving..
irupp33
12-16-2007, 05:51 PM
That looks more like an antenna wire...
Skittle
12-16-2007, 06:03 PM
Yea looks like your missing the wiring harness for the Alpine cd player,The hole thing your holding is for the antenna.
aleister2k
12-16-2007, 06:13 PM
looks like your antenna has a dual wire post instead of a wire surround wire normal setup. Your local bb/ cc should be able to sell you an adapter for it. They may not have it in stock, but hey are generally under $10
kober
12-16-2007, 10:01 PM
oh ok thanks.. ill pick one up tom..
ok well it still wont power up for some reason.. im not sure why.. i just got the 240 and the stock radio never powered on.. so i check the fuses which i replaced the radio fuse.. still no go. the alpine headunit still doesnt power on.. idk what to do now.. argg
Notladstyle
12-16-2007, 10:41 PM
Just run new power wire and accessory wire from the ignition column and run a ground wire to a sanded point against the chassis.
Dealing with old stock harnesses is a hassle that is better skipped.
TJElite
12-17-2007, 05:00 PM
Also, if I remeber right, 240's used a seperate ground on the chassis of the radio...its not in the harness. Most of the aftermarket harnesses have a black wire for you to hook your headunit to, but if you look, it doesn't connect to anything in the factory harness. You'll need to run a new ground, which like dalton said, isn't a bad idea anyway.
Toby
Hotcakes0007
12-17-2007, 08:56 PM
umm the ground on a 240 s13-14 the ant is the ground....just in case no one new also yes its a ant adapter which plugs the stock one in and comes with another for the headunit...
