View Full Version : LHT Turbo Manifold & DP Cost
V8KILLR
12-16-2007, 05:31 AM
What is the price for the LHT Manifold and Down pipe? I currently have a custom A/C Compatible manifold but I like your setup because its more compact and I think it will produce less heat than my setup.
MrLHT
12-16-2007, 11:24 AM
The Log large dia manifold with WG is $395 , 3" stainless with flex joint and flanges $449. We do build them to be as close to the block as possible and plenty of room for AC and fans.
V8KILLR
12-16-2007, 05:53 PM
Thanks for the speedy response
V8KILLR
12-16-2007, 06:02 PM
I for got, I have one more question. What is the max compressor inlet diameter I can use with your manifold? I currently have a GT3076R A/R.60 with a 4" inlet, but I am changing my compressor housing, I just need to know what inlet size that i need.
MrLHT
12-16-2007, 09:26 PM
We can build it to you compressor but a 3" will fit better and give you more room . I run a 3" inlet on the R and make power with plenty of room.
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
