PDA
View Full Version : Help using an Alignment machine
bam2002
12-08-2007, 01:16 PM
I got a great deal on a 90s alightment machine. its a Hunter c111.
It powers up and i can choose the cars from the menue but I cant figure out how to get it to work. I know you need to put the sensors on the rims. Then flip them to calabrate and rotate the wheel 180 deg untill the light flashes green, Then I was rotating it back 180 deg till I got the green light. Then flipping the switch off the "compensate" Setting. I did this on all 4 wheels. Its an old one with the strings so there is no optical to set up. But in the Menue there is a Comensate and Calibrate selection. I dont know what one to use. I also run the self diag test and it sees everything OK except the printer. I dont care about the printer. However would that keep it from working?
So i get the sensors to go green. Lock them so the dont roatate and then go to the main unit to do the Toe and camber. I get no settings?
Any ideas or does any one know how to get a manual? Like a PDF.?
Thanks
bigjim2.5
12-09-2007, 12:52 PM
where located I might be able to come by and show you
bam2002
12-09-2007, 09:59 PM
Im in the Brandon area..
I was informed that you have to turn the wheels when calibrating to get a reading on the Camber and Caster?
Thanks for any input or help..
B
12-17-2007, 11:59 AM
I'm willing to help you get started, but I need to see the machine first.
pm me.-Bob
jegg403
01-29-2008, 10:58 PM
did you find a manual anywhere ? i am looking at a C111 to use in my shop but the guy doesnt know how to do a self test on it thanks any help would be great
bam2002
01-30-2008, 10:06 AM
I emailed Hunter, They sent me the PDF instruction manual free..
