11-29-2007, 10:42 AM
Thanks for the kind words.
I lower cars only enough that the suspension doesn't get beat up, the springs are not rattling loose, and the tires are not being eaten.
Sometimes you will need a camber kit.
I really need to do some measuring to tell you how much lowering works for your particular car/wheel/tire combination.
How bad will the ride be?.........
I recommend spring rates close to what the car was designed to use, unless your car is for smooth race track only, where it is stressed to the limit in every corner..............something that cannot be done on the street without getting in trouble with
the cops...............hard springs also lose grip in the turns on the street when the car is bouncing.......something I have demonstrated
when people ride with me.
Since I can't see the details of your wheels/tires
and fender clearance, we can take the suspension apart, do a detailed analysis, to see how much (and if) your wheel/tire combination will be compatable with what you want it to look like.
Quote:
Originally Posted:
i here ur the man to see.
i got a set of tein s-techs. i want my 16x7 +35 wheels in there flush like coils. so however much it needs to come down how much u charge? and how bad will the ride be?
Quote:
Originally Posted:
