superflyRR
11-27-2007, 08:38 PM
(2) Power Acoustik A600 barely used. $60 each
The Power Acoustik A600-4HP 4 Channel Amplifier with its sleek silver casing and small footprint this amp will be a great addition to your stereo system.
SPECIAL ORDER
Type: PA4Channel
Brand: PowerAcoustikAmps
Brand:Power AcoustikCondition:NewRMS Power Output:85 Watts x 4 @ 2 OhmsBirdged Output:600 WattsSignal To Noise Ratio:97 dB Frequency Response:10-30,000 Hz Bass Boost:0-18 dBBuilt-In Crossovers:HP / LPTHD @ 4 Ohm RMS Power:0.02 %Low Level Input:NoBuilt in Cooling Fan:NoBass Control Knob:NoDimensions:11.25 L x 11 W x 2.3 H
Full Mosfet Power Supply
PWM Circuitry
Full Selectable Crossover Hi/Full/Low
Three Way Protection Circuit
Tri-Mode Capable
Variable Low Pass 40Hz-120Hz
Variable Hi Pass 150Hz-1.5Khz
18 dB Bass Boost @ 40Hz
Frequency Response 10Hz to 30Khz
Signal to Noise Ratio: 97dB
THD: 0.02%
2 Ohm Stable Stereo
System Distress Indicator
High/Low Level Inputs With Floating Ground
4 Gauge Power/Ground Connection
Gold Plated RCA Connectors
Line Output
SPECIAL ORDER
Type: PA4Channel
PWM Circuitry
Tri-Mode Capable
THD: 0.02%
2 Ohm Stable Stereo
Line Output
