PDA
View Full Version : APEXi LS/R - Vs. - AWDTSi
Blood_Sun
08-20-2000, 11:02 AM
This race I cant wait for. Where were you last night awd? I figured you would be down at meridian. Thats where I want to race you next week.
Next saturday you and me. :cool:
1997 Acura Integra (blue)
w/
Secret Ingrediants
MitsuBucci
08-20-2000, 12:58 PM
oh boy...
Invader
08-21-2000, 02:56 PM
Both you need to take it to DeSoto on Friday night (8/25). ;) No excuses...plenty of witnesses.
John
90 Talon TSi AWD
2KW K4U
http://invader.edison.edu/talon/front_quarter_small_04-25-00.jpg
MitsuBucci
08-21-2000, 04:32 PM
Are you running on Friday John?
MitsuBucci
08-21-2000, 05:23 PM
I dont want to go to the track until I get more mods. I go there to much and get the same time.
He should just see me saturday night. I didnt see him at all its like he dissapeared.
Invader
08-22-2000, 11:46 AM
Im going to try and get everything done...I developed a small miss when Im not accelerating and I dont know what it is. Hopefully just a plug or something (a burned valve would really piss me off right now). Probably some small vac. leak or something I cant see.
Anyway Im going to pull the turbo off Thursday and hopefully get it all back together by the end of the evening so I can really flog it on Friday. Im adding the RRE stainless oil feed line new gaskets helicoild a stripped ex. manifold stud O2 eliminator and whatever else I can Thursday night...heheh. Anyway Im hoping for mid 12s Friday night if my rear doesnt break (keeping fingers crossed) and my IC pipes stay on.
John
90 Talon TSi AWD
2KW K4U
16gAWD
08-22-2000, 03:38 PM
12s. What turbo do you have John. My clutch comes in tomorrow and Mitsubishi says not all my gaskets have arrived yet (2 tb and 1 manifold). That will be my project this weekend.
http://www.cs.fsu.edu/~ray/small.jpg
16gAWD
97 Talon TSI AWD
Invader
08-22-2000, 04:08 PM
I have a ported small 16G now...actually its Marios old turbo. I ran a 13.5 on 0.9-1.0 bar (13-14.5 psi) on pump gas and a failing 14B last time...that was the max boost the turbo would push at the last T&T (that and my cooling fan broke so I was running the A/C fan only). The 16G spools 1000 RPM earlier (1 bar at just under 3000 instead of 4000) and holds boost to atleast 1.4 bar (20.5 psi...most I have tried running on pump gas) without a problem. My Karman counts jumped from 1650Hz max to 1950Hz max without changing my boost setting if thats an indication of how bad my 14B was. I was having problems with my coupings coming loose at the 1.4 bar setting but I think Ive taken care of that (Im eventually going to have a bead welded on the pipes now that Erics back in town). It feels like its running low 13s on pump gas now but Im also getting a lot of tire spin in first so I might not be able to get the launch to run those times. My best 60 before was 1.84 so I do need to improve either my launches or my traction (yes Joe...I am eventually gonna get the center diff. welded...probably next week...Ill let you know how streetable it is). I also should have the O2 eliminator installed by Friday...Eric is backed up but promised me that he would have it done by Thursday.
Apparently Im going to have to wait till the weekend to replace all the turbo gaskets so I might still have a few small leaks. Not sure...Im going to keep my fingers crossed. ;)
Only thing Im worried about it my rearend holding up since its still a 3-bolt. Ive heard they can make it into the low 12s but when my axle broke and Chrysler replaced it they didnt seal the diff. cover properly and it drained some fluid out and now it makes a grinding sound...not sure how that will effect the rearends longevity but Id rather break it trying to run a mid-12 than driving around town (atleast I would have *some* bragging rights). :D
The only other thing I can think of thats holding me up is my shifting. Partly due to the fact Im missing a couple bushings in the shifter that Im going to replace (hopefully before Friday) and partly because 90 shifters are just plain shitty.
John
90 Talon TSi AWD
2KW K4U
MitsuBucci
08-22-2000, 04:52 PM
John Cant you replace the bushings with metal washers? I did on mine but I hear the 90s are different.
16gAWD
08-23-2000, 09:19 AM
You can buy this liquid metal header solution to fix any leaks exhaust leaks. I used it on a exhaust leak(bad gasket) and put it around the turbo because my exhaust turbo gasket is bad too. It works great (no leaks) and only $5 at any local auto parts store near the exhaust section. It holds up to 1500 Celcius.
16gAWD
97 Talon TSI AWD
Invader
08-23-2000, 10:57 AM
Found out what the miss was...turns out my alternator died again. Thats number 6 or 7 so far (1 year). I hate rebuilds but atleast the replacements are free. :D Alt. was pushing 11.9V at the battery...with the car OFF the batter was at 12V. I replaced it last night so problem #1 is out of the way.
Joe:
90s are the odd-balls once again. The shifter plate doesnt need bushings to bolt to the floor...the holes are just large enough to fit the bolts (which have a built in washer) so I just bolted it directly to the floor without the bushings. One of the benefits of a 90...probably the only one. :rolleyes:
BUT the bushings that allow the shifter to pivot side-to-side are gone (in the actually shifter assembly). I replaced them with poly washers (as per the VFAQ) but when the bolt loosens slightly my shifter can rock front to back without shifting gears (small movement but not good when speed shifting 3rd). As far as I can tell I dont need any others (I replaced the bushings on the pivot arm at the bottom/back of the shifter - $7.25 each :eek: and I needed 2!!).
James:
The exhaust leak really isnt a big deal...infact I think Ive taken care of it entirely but I wanted to get all the manifold studs tight so I wouldnt have to worry about it. Well that and I didnt replace the ex. manifold gasket last time I had it off (I hate reusing gaskets). And Ive reused my turbo bolts a few too many times and they arent holding like they used too (Im going to put 4 bolts in and forget the stud so I can pull the turbo without pulling the manifold). Right now I just tighten the turbo bolts down every weekend or so...but Id prefer to set and forget. ;)
Providing Debby doesnt force a cancellation Ill be running on Friday. Im eager to see what kind of times I can pull down on pump gas...then Im going to dump in some race fuel turn up the boost and attempt to break the rearend. ;)
Joe...you need to race just so you can bust out a 12 this Friday (assuming we have the T&T).
John
90 Talon TSi AWD
2KW K4U
16gAWD
08-23-2000, 11:55 AM
Looks like Im going jetskiing this weekend. Big waves.
16gAWD
97 Talon TSI AWD
Invader
08-23-2000, 11:59 AM
Thats a damn good idea. Probably be a lot of surfers out too...this weather wont be conducive to racing anyway with the high humidity and low barometric pressure...
John
90 Talon TSi AWD
2KW K4U
AWDTSi
08-23-2000, 03:10 PM
I dont understand it Apexi you wont run at the track because you keep getting the same times. That has nothing to do with it. What does running the same time have to do with winning or losing. I understand you not wanting it at the track because there will be lots of witnesses see you go down but if we race again thats where it will be unless we happen to meet crossing the bridge again sometime but maybe this time you will line up next to me instead of behind me. But if your 15.2 is your time at the track I wont even have to race you but if you insist I will but seeing my times at the track are about high 14s to about 15.1 with my car near stock it will be a good race but you will still go down. If my schedule would let me make it to the street races I would but it never does. I may try and make it to Desoto one of these nights for some final test and tuning to get some more stock times for the car before I start to do mods to it. But not sure when. And yeah you better get all the wins you can get in on the Preludes or whatever because you have a loss coming to your belt.
MitsuBucci
08-23-2000, 07:44 PM
Originally posted by "Someone"
If the weather is ok Ill be running. Probably going to run straight out the downpipe. We will see about the 12...
Joe
94TSiAWD
http://www.cr-racing.com/talonpage.htm
http://www.cr-racing.com/images/smTSi.jpg 13.001 @ 106.55
Blood_Sun
08-24-2000, 09:37 AM
12s 12s 12s...YEAH! :D (sorry for the outburst.)
Invader
08-24-2000, 11:11 AM
You gonna drop the cat-back (err...test-pipe back ;)) entirely? Driving to the track like that? Should be good for a 12 if the weather permits...
John
90 Talon TSi AWD
2KW K4U
Invader
08-24-2000, 03:08 PM
You just keep running your mouth. You will see what happens. Dont always believe times that were run in motor trends and shit. You have no idea how good of a driver you have to be to get those numbers. And since you are not exactly a pro you better hope you get at least a 15.2.
I cant wait to beat you. And if it has to be at a track how about next friday night? Im not sure how my schedule looks but Id be glad to beat you. Just a little bonus my friend in his prelude stayed dead even with a tsi awd with exhaust and some other stuff written on the side. I leave his prelude like nothing. You better prey you can live up to your motortrend stats son because Im about to bring you back to school.
Boom!
w/
Secret Ingrediants
16gAWD
08-24-2000, 03:38 PM
Why not tomorrow night. TampabayDSM will be at Desoto tomorrow. It looks like Debby has died and the weather looks good
You can run low 14s for $70 in a first gen (boost controller and a guage new prices)
You can run low 14s for $270 in a second gen (boost controllerboost guage upper innercooler piping with BOV new prices)
I was getting a 13.9 with a air intake upper innercooler piping w/BOV boosted to 17psi and race fuel)
I dont know what AWDTSI has but these are your usuall first mods to a DSM
16gAWD
97 Talon TSI AWD
[This message has been edited by 16gAWD (edited 08-24-2000).]
16gAWD
08-24-2000, 03:49 PM
I mean everybody knows that those times in the mags cant be achieved without tons of practice. You see those civic sis stock running 15.6 -15.7 and then you have people go to the track to get nothing better than a 16 flat! No affense to rice-rocket I know its hard to get those times. The person who installed all my stuff on my motor pretty much swore that I would only see 14s. And I ran a 15.2 in 95 degree weather. I bet if he was driving in the winter time it would be 14.7 or so. Believe me when I say it driving takes practice and if you dont have practice your just another kid that thinks he knows it all right off the bat.
You will deffinatly see. I hope you stop talking crap to me and just get serious it will be a good race. AND I WONT SAY Ill WIN LIKE YOU DID! Because you dont know. P.s. A talon is a talon. All these people on this site run such good times because of their driving skills you just ask them how hard it was to get good times out of their cars stock. Sorry if im wrong.
Im just saying. You are going to have to do a lot more than talk to beat me in a race. I make my car fast. My car will move but those shifts and good starts are what keeps people seeing my tail lights. And I know it isnt easy to get a good start on those awds. I mean you can get a perfect start of like a 1.9 or 2.0 but it will take a try or two.
Do you guys think Im wrong? I mean come on you can NOT decide that because a book says a time thats what it is. There are so many other factors.
w/
Secret Ingrediants
[This message has been edited by APEXi LS/R (edited 08-24-2000).]
MitsuBucci
08-24-2000, 09:31 PM
Perfect 1.9-2.0?? God!! Id cry if that was all i could do! HAHAHA J/K. I run consistent 1.72 60 foots in my car on radials but you ARE right. It took a LOT of practice to learn how to do it. Anyone who says you can just rev to 7k rpms and dump it is WRONG. Esspecially if their motor is stock. The cor would bog and buck all the way to the 60 mark. I also just learned about a month ago that a 3rd to 4th power shift gained me about 2 tenths.
Still practicing i guess.
Joe
94TSiAWD
MitsuBucci
08-24-2000, 09:51 PM
I will disco my Exhaust at the DP including my track only test pipe. I may take it right off and drive it or just bolt it back together offset so it still looks like it is there. I have a short appointment from about 6pm to 7:30pm but I should be out after that. see you there
Joe
94TSiAWD
AWDTSi
08-25-2000, 07:26 AM
Hey Apexi those times may as well be in a magazine as the stock times but I have timeslips to prove that I have run those times on my car. And trust me I havent been to the track but yet a couple times in my life. My first ever time at the track I was getting flat 15s and with a couple more trips was able to get it into the 14s. So dont worry I am not the type to say something if I cant back it up. In this case I know I can back it up. And I would have to agree with 94TSiAWD if I got 60 times like that I would start to feel sick thats all the fun with an AWD getting 1.7-1.8 60 times. Well hopefully I will get the chance to bury this hatchet soon.
Invader
08-25-2000, 10:33 AM
Joe...Im interested to see how loud it is without the muffler. You have a 2.5 cat-back right? Dropping it should make a huge difference.
As an aside Eric finished the O2 eliminator and I test fitted it. The design is going to take a little modification to fit the AWD since we have the brace that runs just below the radiator...Im going to have Eric modify it slightly to reposition the dump (hopefully).
John
90 Talon TSi AWD (2KW K4U)
http://tampabay.dsm.org
The^Thief
08-25-2000, 02:17 PM
Ill show APEXi some love with FWD on FWD. Then theres no whinning about the AWD advantage. Its just motor on motor going down the track.
I cant wait to hear the excuse he comes up with next. Ill cut a nice 2.3 60 ft with him so its fair. :)
http://tampabay.dsm.org/images/sig-car.jpg
tampabay.dsm.org/members/jpeterso/ (http://tampabay.dsm.org/members/jpeterso/)
tampabay.dsm.org/projects/jpeterso/ (http://tampabay.dsm.org/projects/jpeterso/)
V8 SLAYR
Invader
08-25-2000, 02:25 PM
Oh yeah...thats really fair Jeff...
John
Invader
08-26-2000, 12:13 AM
I wish there was a race from like 80 to 140. Because thats where all my power is. If I get the Type R transmission my car will drop like 6 tenths in the quarter.
w/
Secret Ingrediants
Invader
08-28-2000, 10:56 AM
Excuse my Honda ignorance but how does a tranny help you pick up .6 seconds in the 1/4mi? Is it made of titanium or something that drops 100lbs. off the car? Does it shift itself? Im not seeing it...
John
AWDTSi
08-28-2000, 12:52 PM
Well Invader see its not the tranny that gives him the .6 tenths off its the yellow stickers and badges they give you to stick on the car that does it. lol
MitsuBucci
08-28-2000, 03:33 PM
John the Type-R tranny is geared lower. Like putting 4.11s in the rear end. Dont know if youll gain 6 tenths though... Keep you LS tranny if you plan on going Forced Induction. If you swap it out E-mail 97ex and let him know what you want for the LS tranny...
Joe
94TSiAWD
Invader
08-28-2000, 03:42 PM
Unless you run slicks you generally end up with the same ETs when you gear lower. The gain in ET is usually balanced out by an extra shift. Whole different ball game when you can run slicks (no traction worries off the line or when powershifting)...and of course you accelerate harder when on the run. But .6 seconds off the ET by gearing lower? Thats damned in impressive (I guess I have to keep in mind how high these engines rev).
John
Invader
08-29-2000, 10:59 AM
I have a friend of mine with a 95 Civic with a GSR motor in it and his best time was a 15.6 and then he put in a Type R tranny and now his best time is 15.0. I dont know much about Hondas but it did take alot of time of his run though.
97CavyZ24
16.0 1/4
Invader
08-29-2000, 04:47 PM
Its all about v-tec for people that dont know. It wont drop 6 tenths but it will help like about 4 or 5 tenths. As everybody knows v-tec is where the power is at. With my ls tranny as I shift from 2nd to 3rd gear it drops my car below v-tec rpms which then takes another second for it to hit the vtec and really take off again.
AWDTSI you talk a lot of shit man. I dont even like hearing your jokes about my car. Because all you did was post lies on this site. It just shows your IQ which seems to be extremely low. Stickers or no stickers your a fag. I dont give a damn if you think your car runs 2 tenths faster than my car because I beat 14.6 mustangs on the street! Just keep talking because one day Im going to beat you and its going to make it all the better!
w/
Secret Ingrediants
MitsuBucci
08-29-2000, 07:39 PM
Apex... If you race him... and you beat him...
That makes you a gay basher and that is not politically correct. How does that make you feel?
O.K. ... Nevermind.
Joe
94TSiAWD
LeadSled1
08-29-2000, 08:15 PM
LOL! How did I end up in verbal warfare forum? O.K. whos playing with the links?
AWDTSi
08-30-2000, 07:30 AM
Hey Apexi sorry to hear your taking the stuff the wrong way. You are taking the thing abpout my car being at least .2 faster than yours the wrong way. Sure it may only be .2 tenths faster but then again you have put alot of money in your car with modifications and my car is basically stock. So it just gets better from there with each little mod I install I just get farther and farther in front of you. How much does an LS Tranny cost anyways? Sounds like a costly item for the amount of money it probably costs I can get similar cost mods and shave a whole second off my time at least. But then again thats what DSMs are all about. Pretty quick off the showroom floor and doesnt cost that much to get them faster. Dont worry there will be the day I am sure you and Green Acura will get your lesson handed to you on the track. I dont race on the city streets call me whatever you want to but that is just plain stupid sure I will blow you off the line at a light and take it up to the speed limit so you can see my taillights but you wont ever catch me on Meridian or anywhere racing at night. And if anyone is Gay it is you because is all you will be staring at is the ass of my car all the way down the track.
97ex
08-30-2000, 04:39 PM
AWDtsi im not talkin shit or anything but you shouldnt be all that proud of beating a N/A honda/acura you start with a turbo. you need to set your sights a little higher than that like maybe 94TSiAWD....or even me :D
Ryan
97 civic ex 14.01 97mph
http://www.cr-racing.com/honda1_sig.jpg
_Charles_
08-30-2000, 07:23 PM
I got boost...Wanna play?
RiceRocket & The Blue Bullet http://smilecwm.tripod.com/cwm/silly.gif Eating Fords and Shitting Chevys
marksaccord95
08-30-2000, 11:45 PM
Damn man u run ure mouth a lot of a car that runs low 15s. i mean shit i wouldnt say shit like u say unless i was running 12s-13s. Your car wont run 5 tenths faster when its cold outside. I ran 2 tenths faster 90 degrees vs 55 degrees. Also u wont lose 5 tenths on a type R tranny. my friend has a b16a in his DX and then got the R tranny and lost 2.1 tenths. I mean damn I could throw my stocks on and jet up it up to 65 and I would run all over ure ass but u dont see me talking shit bc i dont think 15.2 is fast yeh its really fast for an accord but not vs. other domestics. Also i have no vtec 104000 miles the stock clutch 4 doors and 3 mods. I bet u if i bouhght ryans slicks I could run u just the way I am right now (as long as the clutch grabbed) so quit saying thats why so many people see my taillights. 75% of the people on this board would walk all over you. Im not in here going I dusted a GSR integra on dale 2 weeks ago most of them see my taillights. I would simply say that was a good race and I like having good races. Calm down man you arent all that fast I sure as hell know that I am not.
And I ran a 15.2 in 95 degree weather. I bet if he was driving in the winter time it would be 14.7 or so.............Its all about v-tec for people that dont know. It wont drop 6 tenths but it will help like about 4 or 5 tenths.
mmmmmm ok http://smilecwm.tripod.com/sp/mackeyico.gif
ZEX etc. check site
http://superhonda.org/board/images/smilies/hondapos.gif
http://www.geocities.com/markaccord95
moderating since feb 2000
_Charles_
08-31-2000, 12:07 AM
Damn Mark...Stop sucking the funny juice...I told you it has some sulpher in it you need medical grade!
16gAWD
08-31-2000, 10:17 AM
sure when and where?
16gAWD
97 Talon TSI AWD
marksaccord95
08-31-2000, 01:13 PM
:D Krumptions sells it but its expensive :D
ZEX etc. check site
_Charles_
08-31-2000, 04:53 PM
Soon my friend...soon. What kinda times ya running? 12s? gotta make it kinda fair...
16gAWD
09-01-2000, 08:59 AM
you can say Im running 12s. Gotta fix my clutch to run 12s again though. I received a clutch this week but it was the wrong one. 6 puck racing clutch. Too strong for this drive train.
16gAWD
97 Talon TSI AWD
GreenAcura
09-15-2000, 10:44 AM
whats funny is that you guys are turbocharged too bad a gsr doesnt come stock with a turbo you guys would really be in bad shape
GreenAcura
09-15-2000, 10:46 AM
And when you say motor too motor that meens no boost so tell me how the race would go witout your boost
16gAWD
09-15-2000, 11:07 AM
Well gee I hope that you can beet the eclipse GS/RS. 1.8L neon engine (145hp). Sorry my car comes with a turbo and the only time the turbo is off is when I will be putting a bigger one on.
16gAWD
97 Talon TSI AWD
Invader
09-15-2000, 12:06 PM
I highly doubt that. Factory cars are detuned to say the least and simply turbocharging a N/A engine wont get you that much performance. Then again Hondas dont weigh shit...could be interesting. Wonder why Honda doesnt do that?
John
90 Talon TSi AWD (http://invader.edison.edu/talon/front_quarter_small_04-25-00.jpg) (2KW K4U)
91 Galant VR-4 (http://invader.edison.edu/talon/galant_front_quarter_small_08-31-00.jpg) (1574/2000)
marksaccord95
01-12-2004, 10:30 PM
so did you beat him joe? isnt this the kid that trailored his 16 sec car, or is that GreenAcura?
robofunc
01-12-2004, 11:09 PM
why is this thread in the autoX forum?
w0rd
01-12-2004, 11:13 PM
It used to be a combined auto-x and drag race forum.
The better question is why did Mark bump a 3.5 year old thread?
robofunc
01-13-2004, 09:09 AM
aha!
