RX-7 1st and 2nd gen information.
Old Feb 7, 2006 | 04:14 PM
Rotary7's Avatar
Get Down-Or-Stay Down
Default Important information for new RX-7 and RX-8 owners.
1st generation '79-'85 RX-7 specs and general info
1979-1980 model "S"
...Base model. 12A engine. 4 speed manual. Drum rear brakes.
...Speedometer standard 1025 revolutions per mile (US standard 1000 revolutions per mile).
...Coolant temp sending unit- 190-260 ohms @ 122 degrees F.
...Coolant temp gauge- hot=16.9 to 21.1 ohms / cold=178.4 to 240 ohms.
...Oil pressure sending unit- engine stopped=74+ ohms / 30psi=43 ohms / 45psi=50-57 ohms.
...Oil pressure gauge- 120psi=10 ohms / 60psi=28 ohms / 0psi=infinity.
...Fuel level sending unit- full=6 ohms / 1/2=31.5 ohms / empty=80 ohms.
...Fuel level gauge- full= 7.4 ohms / 1/2=31.5 ohms / empty= 75.9 ohms.
...4 on 110mm wheel lug pattern. 13" Steel wheels.
...Rear pinion flange bolt pattern- (4) .325 holes on 2.946" bolt circle (rectangular pattern). 1.772" dia male pilot.
...3.909 rear gear ratio.
...0.825 5th gear ratio.
...2350lbs manual
1979-UP model "GS"
...2nd level model. 12A engine. 5 speed. Drum rear brakes. Rear Torsion bar. Electric fuel filler and rear hatch releases. Sunroof optional.
...4 on 110mm wheel lug pattern. 13" mag wheels.
...2385lbs manual (2450lbs automatic)
1980 model "LS"
...GS with black paint. 12A engine. 5 speed. Drum rear brakes. Electric mirrors. Leather. Only 3000 produced.
...4 on 110mm wheel lug pattern. 13" Gold painted mag wheels.
...2385lbs manual (2410lbs automatic)
1981-UP model "S"
...Base model. 12A engine. 5 speed. Drum rear brakes. Steel wheels/4 on 110mm wheel lug pattern. Shifter moved back 2". Increased fuel tank capacity. Space saver spare tire. Licnese plate moved under bumper. Soft bumper faces.
...2335lbs manual
1981- model "GSL"
...Deluxe model. 12A engine. 5 speed. Rear Disc brakes. Limited slip diff. Leather interior. Electric windows. Sunroof. Mag wheels/4 on 110mm wheel lug pattern.
...2455lbs manual (2480lbs automatic)
1983-UP ALL models
...Keylock removed from gas filler. 130 mph speedo in US. Single windshield squirter replaced by dual.
1983 model "LE"
...Limited Edition. Champagne Silver paint. 12A engine. 5 speed. Drum rear brakes. 14" wheels/4 on 110mm wheel lug pattern.
...4 on 110mm wheel lug pattern. Both 13" and 14" mag wheels.
...Rear pinion flange bolt pattern- (4) .333 holes on 3.500" bolt circle. 1.772" dia male pilot.
1984-85 ALL models
...Brake vents added to front air dam. 140 mph speedo in US. Lower rear control arm's front mounting point lowered 20mm to increase roll understeer.
1984-85 model "GSL"
...Mid level model. 12A engine. 5 speed manual (4 speed automatic optional). Disc rear brakes. Aluminum wheels/4 on 110mm wheel lug pattern. Buttons instead of levers for air control. Leather interior no longer standard in GSL.
...4 on 110mm wheel lug pattern. 14" mag wheels.
...0.808 5th gear ratio.
1984-85 model "GSL-SE"
...Deluxe model. 13B fuel injected engine. 5 speed only (no automatic). Bigger 4 wheel disc brakes. Aluminum 14" wheels/4 on 4-1/2" wheel lug pattern. Better oil cooler. Optimized transmission ratios. Larger fuel lines/larger fittings in fuel pick-up.
...Front motor mount holes in crossmember re-located 20mm (.788") farther forward to accomodate longer 13B engine.
...4 on 4-1/2" wheel lug pattern. 14" mag wheels.
...'84 model came with a 4.083 rear gear ratio.
...'85 model came with a 4.077 rear gear ratio.
...0.758 5th gear ratio in 1984.
...0.715 5th gear ratio in 1985.
...2460lbs manual (2485lbs automatic)
2nd generation '86-'91 RX-7 specs and general info
1986-88 models "BASE", "SPORT" and "SE"
...Base model. SE is an 87-88 (i think) that has 4 lugs wheels, base suspension, sunroof(optional), ac, 146hp.
...4 on 4-1/2" lug pattern. 14" wheels. 2 piston calipers.
...Rear pinion flange bolt pattern- (4) .393" holes on 3.786" bolt circle. 1.772" dia male pilot.
...4.10 rear ratio w/ manual, 3.909 rear ratio w/ automatic.
...0.711 5th gear ratio.
...2625lbs manual (2695lbs automatic)
1987 model "Sport"
...2nd level model.
1986-88 model "GXL"
...Luxury model with leather, cruise, ac, power door locks, power windows, auto adjust suspension, rear wiper. 4 pinion clutch type LSD.
...5 on 4-1/2" lug pattern. 15x6" wheels. 4 piston calipers. Vented rear rotors.
...0.711 5th gear ratio in '86. 0.697 5th gear ratio in '87/'88.
...4.10 rear ratio w/ manual, 3.909 rear ratio w/ automatic. 4 pinion clutch type LSD standard equipment.
1989-91 model "GXL"
...The 89-90 GXL did not have standard leather interior -- leather was optional.
...4.10 rear ratio w/ manual, 3.909 rear ratio w/ automatic. Viscous LSD optional.
...0.697 5th gear ratio.
...2800lbs manual (2844lbs automatic)
1987-88 model "Turbo II"
...manual trans only.
...5 on 4-1/2" lug pattern. 16x7" wheels. 4 piston calipers. Vented rear rotors.
...Rear pinion flange bolt pattern- (4) .410" holes on 4.120" bolt circle. 1.772" dia male pilot.
...8" ring gear / 4.10 rear gear ratio. Clutch type LSD standard.
...0.719 5th gear ratio.
...2844lbs manual
1989-91 model "Turbo II"
...3003lbs manual
1988 model "GTU"
...According to a table in the Mazda parts microfiche, there were two GTU models made during 1988. One GTU model came with a sunroof and did not have LSD. The other GTU model did not have a sunroof, but did have LSD. They both had the hard suspension which included 4-piston calipers and vented rear rotors, and 5-lug hubs.
...5 on 4-1/2" lug pattern. 16x7 wheels. 4 piston calipers. Vented rear rotors.
...0.758 5th gear ratio.
1989-90 model "GTU"
...Base model.
...5 on 4-1/2" lug pattern. 16x7" wheels. 2 piston calipers.
1989-90 model "GTUs"
...Basically a Turbo II without the Turbo. Lighter by a few hundred pounds (2800lbs vs T-II @ 3045lbs), and had the short 4.3 final drive ratio and a special close-ratio fifth gear. It had the Turbo wheels (16x7, 5 on 4-1/2" lug pattern), Turbo suspension, Turbo brakes (4-piston), Turbo seats, and so on. What it lacked were power windows, power door locks, door panel lights, cruise control, rear wiper, and sunroof (except by special order). Cloth interior was mandatory, but the steering wheel and shift knob were leather. It was only available in Black, Red, and White. Additionally, it had less sound insulation. Radio only. AC was a dealer option; not factory. Aluminum hood and aluminum jack. It was the ultimate non-turbo. 89 was also the year all the non-turbos got the power increase from 146 to 160 hp.
...4.30 rear ratio. Viscous LSD standard.
1988 model "Convertible"
...4.10 rear ratio w/ both manual and automatic.
...3003lbs manual (3053lbs automatic)
1989-91 model "Convertible"
...3045lbs manual (3105lbs automatic)
Do you want to be tazed?
