proracer718
11-15-2007, 11:52 AM
http://ksportusa.com/grfx/products/coilovers/cd01/splash_large.jpghttp://ksportusa.com/grfx/products/coilovers/cd01/1_large.jpg
check out the site for a list of available applications and other products Ksport has to offer.
Ksport USA - Performance Suspension (http://ksportusa.com/asp/coilovers_detail.asp?product_id=cd01)
PM ME FOR APPLICATION AVAILABILITY AND PRICING
Kontrol Pro Damper System
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Key Features:
36 levels of adjustable dampening
Made from high quality 6061 aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Pillowball top mount with adjustable camber (not available for some models)
Monotube high pressure design reduces oil leakage
Electroplated body for protection from corrosion and rust
One year limited warranty
Also Available are the RLCA, front & rear camber kits as well as many other suspension products.
http://ksportusa.com/grfx/products/camber_toe/ct01/splash.jpg
http://ksportusa.com/grfx/products/camber_toe/ct02/splash.jpg
http://ksportusa.com/grfx/products/rods_arms/ra01/splash.jpg
http://ksportusa.com/grfx/products/springs/sp01/splash_large.jpg
Key Features:
