PDA
View Full Version : Nitto tires offered at RXmotos!!!!
RXmotors
11-06-2007, 01:53 PM
Hello Guys,
We carry the full line of Nitto Tires.
(NEW) The Nitto Invo
The invo is a ultra-high performance street tire that delivers an optimal balance of wet performance, dry performance, ride comfort and refinement. State-of-the-art computer engineering software and specialized digital testing equipment were used to produce an exceptionally quiet tread pattern that reduces perceived pattern noise. The Invo is non-directional so that owners can rotate tires on staggared fitments. This freedom of rotation reduces abnormal wear for a smooth, quiet ride throughout the life of the tire. The Invo is a ideal balance of performance and ride comfort. It is the perfect complement to your luxury performance vehicle.
http://img128.imageshack.us/img128/5047/nt20invotj4.jpg
The Nitto NT555
The Nitto NT555 is a summer-oriented ultra-high performance street tire designed with the performance driver in mind. With one of the largest contact patches available, the NT555 provides superior traction and reliable handling without sacrificing tread life. Both tread pattern and compounds were optimized for dry performance. The highly rigid tread blocks provide stability while prolonging the life of the tire. The NT555 will get you off the line quicker, provides stability and confidence in the corners.
http://img88.imageshack.us/img88/438/nittont555extremeperforbi9.jpg
The Nitto Neogen.
The Neogen is an all-season ultra-high performance radial specifically engineered for lowered vehicles. Because the inner shoulder is one continuous block, the tread maintains stabillity on lowered vehicles with higher degrees of negative camber. This stability reduces tread flex and allows the tire to wear more evenly. The result is a tire with prolonged performance on lowered vehicles.
http://img88.imageshack.us/img88/5385/neogenbb3.jpg
The Nitto NT450
The NT 450 is an entry-level-high performance radial designed for all-season performacne. The unidirectional tread design perfroms exceptionally well in wet weather by evacuating water through the slanted grooves and lateral slits. The double center rib provides increased stability on straight-aways, during braking and during accelerating. The NT450 is ideal for enthusiasts who demand performance and affordability.
http://img252.imageshack.us/img252/3672/34928958gz4.png
You can go to Nitto Tire - High Performance Tires for Car and Truck Enthusiasts (http://www.Nittotire.com) to check for sizes needed.
Guys pm me or call 813-873-2235 for pricing.
Also we have in house mounting and balacning. I have been mounting low profile tires for 10 years. Also we have the top of the line Hunter balancing machine (16k).
Thanks
Charles
