92mugenintegra
11-02-2007, 06:32 PM
WE DO FULL POWDER COATING AND ALSO DO CERAMIC COATING.
HERE ARE SOME OF ARE PRICES ALSO REMEMBER I WILL BEAT ALL OTHER POWDER COATERS PRICES IF YOU FIND THEM CHEAPER THAN ME.
MEDIA BLASTING
we do media blasting so if u would like your part to look like new we can make it happen.
CUSTOM WORK
we also cut valve covers to show your cam gears. we do not recommend the the whole cam cover be remove for possible debris getting in your timing belt. if you do select this to be done we ask you to sign a waver to cover use. Something we have to do sorry. $20
CUSTOM PAINTING
WE DO CUSTOM PAINTING FOR YOU THAT WANT A PERFECT MATCH TO YOUR CAR. WE ALSO DO CUSTOM WORK FAR AS DOING PAINT WORK ON VALVE COVERS WHERE IT WOULD TAKE TO MUCH TIME AND COST TO MUCH. WE ALSO DO INTERIOR PARTS AND TAIL LIGHT SMOKING. ASK USE WHAT YOU WANT DONE AND SEE WHAT WE CAN DO THANKS.
SHAVING
We can also shave valve covers and other items. contact use for pricing due to different price on what we have to remove.
clear powder coating
$20-$40 we recommend this to be done on polished parts this will keep the item from finger prints staining an oxidizing. the item will always look new and not much to do when you got to a show but to wipe it down. never polish again.
Valve Covers
$50 single stage colors
$75 two stage colors
$20 clear coat recommended for UV protection and more chemical resistant.
Intake Manifolds
$40 single stage colors
$60 two stage colors
Front Brake Calipers
$55 single stage colors
$80 two stage colors
Rear Brake Calipers
piping
$15 per ft single stage colors (up to 3.5 foot)
$22.50 per ft two stage colors (up to 3.5 foot )
$20 for clear coat recommended for UV protection and more chemical resistant.
wheels
15" $55 (each)
16" $60 (each)
17" $65 (each)
18" $75 (each)
HIGH TEMP CERAMIC COATINGS.
CHROME 1300-DEG.
WHITE 2000-DEG.
TITANIUM 2000-DEG.
BLACK SATIN 2000-DEG
CAST IRON 2000-DEG.
ALUMINUM 2000-DEG.
STOCK MANIFOLD $65 $90
HEADER $75 $95
8-CLY STOCK MANIFOLD $125 $150
TURBO/SHORTIE'S $150 $175
LONG TUBES $200 $250
HIGH TEMP POWDER COATINGS
1000 Degrees Resistant
Smooth Black
Black Texture
Silver Texture
STOCK MANIFOLD $50 $70
HEADER $60 $80
8-CLY STOCK MANIFOLD $100 $140
TURBO/SHORTIE'S $120 $160
LONG TUBES $180 $220
SPECIAL ORDER COLORS
The price for special orders is based on the color type an how much is required for your item.
Shipping prices
Valve Covers: $15 in the US
other items are based on your location and whats being shipped size an weight.
core charge
we charge a $45 core on valve covers that we have in stock for cores. you will receive your core charge back when we get your core back in from you. your core must be in the same condition as you receive ares. we mean that it must not have dings / dents / gouges / cracks / chips.
MEDIA BLASTING
CUSTOM WORK
CUSTOM PAINTING
SHAVING
Valve Covers
Intake Manifolds
Rear Brake Calipers
piping
wheels
15" $55 (each)
16" $60 (each)
17" $65 (each)
18" $75 (each)
CHROME 1300-DEG.
WHITE 2000-DEG.
TITANIUM 2000-DEG.
CAST IRON 2000-DEG.
ALUMINUM 2000-DEG.
HEADER $75 $95
Smooth Black
Black Texture
Silver Texture
HEADER $60 $80
Shipping prices
core charge
