PDA
View Full Version : is this a bad idea
bryson240
11-01-2007, 01:19 PM
have an mdf box. then just put a layer of fiberglass and resin over it so i can paint it?
MilanoCivic97
11-01-2007, 01:29 PM
not a bad idea at all. you could probably get away with painting just the mdf with a high build primer and a few coats of paint though.
the727kid
11-01-2007, 01:39 PM
Make sure you round over all the corners though!
bryson240
11-01-2007, 02:56 PM
alright becuase i want to have the fiberglass look but my friend but a full fiberglass bos and it sounded like crap like rattley
POST
11-01-2007, 04:29 PM
what?
bryson240
11-01-2007, 04:49 PM
he made a fiberglass box and it was like rattley sounding then he made a mdf box and it was clean
POST
11-01-2007, 05:41 PM
A fiberglass box shouldn't sound "rattley" at all. The fiberglass makes the box a one, super-solid, airtight piece.
pour the fiberglass and "paint" it all on the inside of the box, this will make it even more solid and airtight. Then you can paint the outside of it just fine.
integralsgreen
11-01-2007, 06:14 PM
i use spray polly. mdf seems to suck up primer like a sponge. and with a good urethane primer it can get expensive. coating it with fiberglass resin works excellent too just a little harder to sand smooth. you can also mix some bondo in with some fiberglass resin, mix it up to a good sprayable viscosity, add mek hardener and spray it out of a paint gun. it will lay flat so less sanding, and easier to sand than just straight resin, kind of a poor mans spay polly
