PDA
View Full Version : boost leak i guess...
Ls_[eg]hatch
10-29-2007, 05:13 PM
i just got my srt-4 and it was running fine but now the boost like spikes or surges donno witch one...any suguestions?
cali
10-29-2007, 06:26 PM
which one? Spikes or surges?
Surging would be up and down. Spike would be hittting a sudden max and then normalizing.
Could be anything form vac line leak to exhaust leak.
KrazyRider83
10-30-2007, 08:15 AM
most likely a boost leak...common & usually simple to fix
SRT4beepo
10-30-2007, 08:27 AM
if u have aftermarket piping could be cold side or hot side pipes to much boost poped it off its common...
could be alota things a cap or a vaccum line poped off.. check ur car 1 by 1.. look at last thing u touched or installed.. work from ther!
Ls_[eg]hatch
10-31-2007, 01:22 AM
i checked them all well atleast the ones i could see there all good,iv read that srt-4's are common for waste gate problems...
Ls_[eg]hatch
10-31-2007, 01:25 AM
idonno like i can ease into it and its fine,it when i step straight on toit it's liek theres not enough full or air too it but iv checked everything...and it seems to do it mostly in 3rd...
Figs
10-31-2007, 05:55 PM
Your in St. Pete and so am I. I work on these cars so I can do a boost leak test for you and check out what's going on with your car.
PMed you some info.
Ls_[eg]hatch
11-05-2007, 01:06 PM
found out what it was i guess the spark plug set up on 03-04 is shitty and they seem to fry after low milage and all i need to do is buy a msd coil and wires pack
