PDA
View Full Version : MegaSquirt v3 or MapEcu2?
Ricksta
10-26-2007, 06:40 PM
megasquirt being full ems, its what i really want. its gonna cost me prolly about 600 bucks to fully get things running. but its going to be a lot of work and i mean A LOT. ive been told of a way to get it to work properly and hear nothing but good things but i dont exactly know anything about tuning just yet. i want to learn to tune myself so this is why i want to get ms.
on the other hand you have mapecu2. its a piggy back system thats 700 bucks and includes an electronic boost controller as ms does not. i hear a lot of good and bad things about it. some people say it works and some people sais it doesnt. i basically get the same speach about both setups. so im wondering if anyone has any experience with any of the two on a 3sgte.
christo4_99
10-27-2007, 09:27 AM
MegasquirtnSpark-extra (http://megasquirt.sourceforge.net/extra/boost.html)
Ricksta
10-27-2007, 02:48 PM
it sais its experimental?
B18C5-EG
10-28-2007, 05:16 AM
megasquirt all the way. read read read. chances are someone out there has done the same thing your thinking so look through the MS files people have uploaded so you can get a decent basmap to work with instead of starting from scratch (not for the beginner). and MS is only 250$, 20$ tuning cable, 40$ for the attachable harness. and with the money you save you can buy an EBC.
christo4_99
10-29-2007, 12:06 PM
it sais its experimental?get ahold of ryan,he has set up several megasquirts on mr2s...i'm sure there is a way to control boost and knock and everything else involved...from what i have read the major problem with the 3s is a "noisy" analog timing signal...but there is a whole section of mr2oc dedicated to ms...a lot of people use the ford edis for ignition with the ms and from what i understand the guts of the stock ecu can be used to trigger it...if not a trigger wheel and sensor can be installed at the bottom pulley to trigger it...
Ricksta
10-29-2007, 07:20 PM
once i get the unit im gonna start readin up on it. but if i can incorperate a ebc into the ms that would be totally knarly!
Ricksta
10-29-2007, 07:21 PM
smitty told me all about this. im gonna get on the ms boards and find out everything i gotta know maybe a write up.
