PDA
View Full Version : SR, is this TDC?
doodoobrown69
10-21-2007, 02:32 PM
is at TDC?
SR popular drift motor so it ok to post here :)
http://i29.photobucket.com/albums/c265/StinkyPink/100_5606.jpg
http://i29.photobucket.com/albums/c265/StinkyPink/100_5607.jpg
http://i29.photobucket.com/albums/c265/StinkyPink/100_5608.jpg
Chin
10-21-2007, 07:46 PM
Its either really close or that is TDC I think you might need to have to turn the crank slightly clockwise but its really close. But both cams are pointed out which is correct.
doodoobrown69
10-21-2007, 07:58 PM
i cant find a wrench to fit on there, i cant get an adjustable
to lock on there at all either
http://i29.photobucket.com/albums/c265/StinkyPink/cams.jpg
Chin
10-21-2007, 08:06 PM
on the crank dude. put a 12 Inch extention in the spark plug hole and get it at its peak. the CAS will take any small mistakes for being off slightly.
doodoobrown69
10-21-2007, 08:20 PM
im talkin about breaking loose the bolt on the camshaft sprokets
Chin
10-21-2007, 09:00 PM
I believe off the top of my head its a 24 mm wrench you need.
titan uranus
10-21-2007, 11:07 PM
1"
doodoobrown69
10-22-2007, 12:59 AM
1"
ya, i thought it was 1 inch, i cant get the 1" or an adjustable to fit on it, idk
Mars_302
10-22-2007, 01:03 AM
27mm I bet
marksaccord95
10-22-2007, 03:55 PM
yea thats pretty close, its 2.5 links to the dot on intake, 9 links to exhaust then i believe another 3.5 down, thats if your looking level to the top of the head
Chin
10-22-2007, 07:47 PM
1 inch = 25.4mm
Jordan T
10-22-2007, 09:38 PM
put an socket extension in there, when it goes as high as it can give it a small turn but not enough to let it recede much back in. you want it in the very beginning stage of combustion stroke.
titan uranus
10-22-2007, 10:33 PM
Why dont we just look at the marks on the crank? there really isnt any way for those to be off. and I just completly dissasembled an sr from long block to absolutly nothing, literally 5 min ago, and I used a 1" wrench to hold the cams.
marksaccord95
10-22-2007, 10:37 PM
disassemble is easy, reassemble and running correctly are 2 different things.
the correct way is to read it thru the cam markings above. if you want to get REALLY close, get a dial caliper
doodoobrown69
10-22-2007, 10:52 PM
i just google'ed that, isnt it used to measure lengths? what do you measure?
doodoobrown69
10-22-2007, 11:28 PM
sean at Central Automotive showed me the wrench to use, a 26mm, grinded down on the side to make it thin! worked like a charm!
you guys wanna see more pics of my motor's internals??
i think theyr cool!
titan uranus
10-23-2007, 08:20 AM
i think theyr cool!
You could do that too, but all I have is a 1" maybe one day ill buy all the cool big metric stuff
doodoobrown69
10-26-2007, 11:55 AM
here they are!
http://i29.photobucket.com/albums/c265/StinkyPink/DSC00513.jpg
http://i29.photobucket.com/albums/c265/StinkyPink/DSC00520.jpg
http://i29.photobucket.com/albums/c265/StinkyPink/DSC00519.jpg
http://i29.photobucket.com/albums/c265/StinkyPink/DSC00512.jpg
http://i29.photobucket.com/albums/c265/StinkyPink/DSC00511.jpg
http://i29.photobucket.com/albums/c265/StinkyPink/DSC00533.jpg
oops.....
