PDA
View Full Version : How To:Boost Gauge Brass T Fitting
rex'03
10-20-2007, 11:37 PM
I thought I'd make this quick how-to on making a permanent fix to the T fitting connecting the vacuum/ capillary tubing going from the bypass valve to your boost gauge inside the car. My specific gauge that I have is an Auto meter 30 PSI Pro comp. I experienced failure with the plastic, and rubber connections associated from the Lamco /auto meter parts to connect everything together out of the box originally. It's pretty self explanatory with the part's, and how to put everything together. I now have no more boost loss, and everything runs as it should.
Place of purchase for parts: Home Depot, and Advance Auto Parts.
Process: The main part is the T block that puts everything together. I used two 1/4" barb fittings to connect the by pass valve vacuum hose securely to the T block. On the third port I used an adapter, and a compression fitting with Ferrel to secure the capillary tubing connecting the line going to my boost gauge. Please refer to the pictures for a part's listing, and pictures of the completed project. The time this project took me was forty minutes..
EDIT: Make sure you use Teflon tape, or Teflon sealant to ensure you have a good, tight seal on your item's being assembled.
http://i185.photobucket.com/albums/x210/REX03_bucket/IMG_4223.jpg
http://i185.photobucket.com/albums/x210/REX03_bucket/IMG_4222.jpg
http://i185.photobucket.com/albums/x210/REX03_bucket/IMG_4219.jpg
http://i185.photobucket.com/albums/x210/REX03_bucket/SCAN0210.jpg
http://i185.photobucket.com/albums/x210/REX03_bucket/SCAN0209.jpg
http://i185.photobucket.com/albums/x210/REX03_bucket/SCAN0208.jpg
http://i185.photobucket.com/albums/x210/REX03_bucket/SCAN0207.jpg
http://i185.photobucket.com/albums/x210/REX03_bucket/SCAN0206.jpg
http://i185.photobucket.com/albums/x210/REX03_bucket/SCAN0205.jpg
Eric
blacksti
10-21-2007, 01:05 AM
thats sweet but you could have went through a lot less trouble
rex'03
10-21-2007, 02:08 AM
gringoplaya
10-21-2007, 02:13 AM
My car came with one stock lol.
but good write up :thumbup:
TYJaMO
10-21-2007, 02:34 PM
Home Depot DIY FTW!!!
