View Full Version : What's more beneficial?
05stisilver
10-20-2007, 11:32 PM
What's more beneficial for usable power band for a 35r/40r?
Displacement (2.65L) or Rev Limit (8k-8.5k)?
ryan_west06
10-21-2007, 12:19 AM
id like to know....
blacksti
10-21-2007, 01:02 AM
ur sells a twin scroll 40r that spools 500rpm quicker then there 35r
SnowMann
10-21-2007, 01:33 AM
An 8.5k rev limit would result in much more usable power band than the added .15L of displacement.
LDadrenaline
10-21-2007, 01:58 AM
.15 litre displacement AND the 8.5k redline :D
definitely rev limit. your power band might be a similar length with either, but the rev limit would make it in high RPMs which would probably end up in a HIGHER usable power band as well.
05stisilver
10-21-2007, 05:54 AM
That kit is a custom kit that was made for the big valley sti.........And from what I have read is like 10k (don't remember exactly). It's not the normal 40r kit on their site
-faded-
10-21-2007, 09:52 AM
higher rev limit would be better
I'm Slow
10-21-2007, 12:45 PM
Def rev limit. Those turbos own uptop in the rpms. For street I say 35r.....for track only then 40r
blacksti
10-21-2007, 03:11 PM
i talked to them dirrectly they sell it but tis not listed on their site... they also said theyve sold it to a lot of people with street cars... its 7k for the kit but its comes with everything i was thinking about getting it when i build my bolck
ImportImageRacing
10-21-2007, 05:00 PM
i agree with snowman, higher revlimit will be best. as is on my 30R with just .82 on stock dispacement my peak hp # is at redline...meaning im still gaining...everything relative..moving the powerband to the right, would make one think you'll want quite a bit more room with revs.
05stisilver
10-21-2007, 07:12 PM
As far as the 40r kit goes....and if I had to do it over which is what I wanted to do....but would have lost alot of time/money on it was get one of these kits........
Full-Race Motorsports LLC Call us toll free at (866) FULL-RACE (http://www.full-race.com/catalog/product_info.php?products_id=1834&osCsid=9140386454f049b78e787ca53dbb6783)
They also have the first twinscroll 35r kit that I have seen and their 40r kit is cheaper then the UR and in my opinion its better(may not be)
05stisilver
10-21-2007, 07:43 PM
I feel the same way but...........I was trying to cheat and just get a built bottom end. Do you feel that if the rev limit was only 8k if would still be the best route?
Unfortunately if the rev limit is the main factor I have to do both.............bottom end and heads/cams........and I won't be able to do a 2.65L because it's not recommended to rev that high (only 7300'ish)
#6 (http://www.tamparacing.com/forums/showpost.php?p=4719297&postcount=6) (permalink (http://www.tamparacing.com/forums/subaru-tech/435546-whats-more-beneficial.html#post4719297)) KAX (http://www.tamparacing.com/forums/member.php?u=17055) vbmenu_register("postmenu_4719297", true);
Car:
My TRGarage (http://www.tamparacing.com/forums/vbgarage.php?do=viewparked&id=17055)
http://www.tamparacing.com/forums/customavatars/avatar17055_0.gif (http://www.tamparacing.com/forums/member.php?u=17055)
TRader Rating: (0 (http://www.tamparacing.com/forums/itrader.php?u=17055))
http://www.tamparacing.com/forums/styles/trnight/reputation/reputation_pos.gif: 4522
-faded-
10-22-2007, 01:55 PM
hell, i wish i had longer reline with my FP green, 8.5K would have been a blast.
homemade wrx
10-22-2007, 05:44 PM
a larger hotsided 35r would have a nicer torque curve unless you were to run a mid size 40r with some larger drag cams...the 35r would still have an earlier torque curve though.
the 40r setup that spools faster is also a very small a/r hotside with a twinscroll hotside...UR hasn't made a twinscroll 35r kit yet...I'm still buttoning mine up ;)
are you trying to make a drag setup or a roadcourse setup? aside from street driving, that is...
As for the shortblock, I'm doing a real long rod and comprable redline (redline being peak g's) to the EJ257s rod ratio puts me at 9200 with the same absolute acceleration rate...yes, I'm a mechanical engineer/IC engine nerd.
Don't worry, I have a few tricks I'm doing for the oiling system as well...I do have to give up a few cc's of displacement to the 257 though...I do have better discharge coefficients and quench height though...also a nicer quench pad
I'm not a fan of short rod ratios unless you are an auto-x'er or a short road course torque fanatic. Hence my questioning the purpose of the build. Pending what you want, there are most likely better shortblock options than a stroker.
Content Relevant URLs by
vBSEO 3.2.0 RC5
