PDA
View Full Version : FS: 2006 Honda Rancher 350 ES ATV (utility)
boostedb16a3
10-20-2007, 02:56 PM
Up for sale is an Olive green 2006 Honda Rancher 350cc Electronic shift. This ATV is equipped with a 2x4 system that has ample amount of power to navigate through all-terrains that are encountered. The rancher is fully digital as you can see in the pictures, and is in great condition with minimal scratches on the plastics. I've taken great care of this ATV and I purchased it brand new. There's about 290 easy driven miles on this ATV, and has only been operated for about 46 hours. That's very low miles/hours, and is priced to sell. I have minimal use for it these days and would rather go to a suitable owner instead of being storaged. More pictures available upon request.
I can be reached via email @ jjeanlouis@yahoo.com or via cell phone 386.216.5422.
$3350 obo
Here are the specs of this ATV:
ATV Type : Utility Quad Bikes
Model ID : TRX350FEM6
Engine
Engine Detail : 329cc air-cooled dry sump longitudinal OHV 4-stroke single cylinder
Engine Capacity : 329cc
Valve Spec : OHV
Type : 4-stroke
Cooling : air-cooled
No of Cylinders : single cylinder
Bore / Stroke : 78.5 mm x 68.0 mm
Lubrication : dry sump
Ignition : CD with electronic advance - Electric with recoil backup
Gearbox
Transmission : 5 fwd/1 rev - auto clutch with electric shift (ESP)
Fuel
Fuel System : 32mm CV
Fuel Tank Capacity (Gal) : 3.43 gal.
Fuel Tank Capacity (Liters) : 13 liters
Dimensions and Weight
Length (Inches) : 78 in
Width (Inches) : 43.86 in
Height (Inches) : 48 in
Seat Height (Inches) : 32 in
Ground Clearance (Inches) : 7.32 in
Wheelbase (Inches) : 49 in
Dry Weight (Lbs) : 536 lb
Length (mm) : 2031mm
Width (mm) : 1114mm
Height (mm) : 1219mm
Seat Height (mm) : 822mm
Ground Clearance (mm) : 186mm
Wheelbase (mm) : 1253mm
Dry Weight (Kg) : 242 kg
Suspension, Brakes and Tires
Suspension - Front : Independent double-wishbone 150mm (5.9 in) travel
Suspension - Rear : Swingarm with single shock 150mm (5.9 in) travel
Brakes - Front : Twin leading shoe, triple sealed hydraulic drums
Brakes - Rear : Sealed mechanical drum
Tires - Front : 24 x 8-12
Tires - Rear : 24 x 9-11
boostedb16a3
10-20-2007, 03:00 PM
http://www.tamparacing.com/photopost/data/500/medium/IMAGE_00016.jpg
More pics available upon request...
