View Full Version : lic. plate rattling?
.Seth.
10-15-2007, 10:42 PM
ok well my lic. plate keeps rattling lol, anyone have any ideas? its just the lic. plate im worried about, I was thinknig about putting some foam(the one w/ the sticky shit on one side and not the other) but wanted to see wat everyone else is using first
pnrcaraudio
10-15-2007, 10:51 PM
Never tried that but it is a cheap way of trying to fix it if it does not work we have license plate sound deadening kits which are relativly inexpensive too.
.Seth.
10-15-2007, 10:57 PM
^how much? i wouldnt mind doing biz w/ u again lol
Noobz
10-15-2007, 10:59 PM
i used tape foam from autozone its for truck campers and you will have alot left over hahahaha
.Seth.
10-15-2007, 11:01 PM
^thats wat i was talking about, i didnt know the name of it lol
MilanoCivic97
10-15-2007, 11:33 PM
just put some sort of foam barrier behing the plate and make sure it is tight. cheap and easy fix.
Notladstyle
10-16-2007, 09:50 AM
I just put all four screws in... no need for foam if you brace it properly.
rangcrx
10-16-2007, 10:39 AM
i use 3dollar roll from walmart the stuff used to seal windows and doors its really strong just run it around the back of the plate then drill holes where the screws will go and your good,so it raises the plate up lil from the car
CHUPA_CABRA_2.0
10-16-2007, 10:54 AM
Look even easier and cheaper. Get 2 thick mouse pads (from work like me) cut them to size and epoxy them to each other and then to the plate. I spent under $5.00 and it works perfect
.Seth.
10-16-2007, 11:42 AM
I only have 2 lic. Plate holes so that's out of the question. But I was thinking about the window seal as well but idk if I wanta stick it on my car or not and run the risk of damaging the paint. And I need to secure the plate and the plate cover
rangcrx
10-16-2007, 11:51 AM
it only has sticky on one side thats the side you stick to the plate not the car and its really sticky,and foam is soft so will not mess anything up
rangcrx
10-16-2007, 11:55 AM
like this
Reed Rubber | Acrylic Foam Mounting Tapes and Spacer Tapes (http://www.rubber-gaskets.com/mounting-tape.html)
this says it alll
"Features excellent vibration dampening & impact resistance qualities"
Thats why you stick it to the plate. I did that on my old civic. Works fine.
the727kid
10-16-2007, 02:18 PM
2 sided tape....same stuff you use to put emblems on....just rip it off when you need a new plate or sell the car.
Content Relevant URLs by
vBSEO 3.2.0 RC5
