????? About My Cams
I wat told that my cam has a flat lope.. OK my car makes a ticking sound. Only does it when i maintain speed.. Not when i speed up or slow down..
If any had an idea at what this could be please tell me what it is The Eng is a 420a does it sound like a cam or crank
maybe lifters..
is it a stock cam? how long has it been doing this?
is the ticking the same all the time everyday, or does it change?
if nothing else seems wrong and you are not losing any performance, maybe just try a thicker oil. I know with the 4g63 the lifters tick very loud naturally. I dont know about the 420a.
+1 Annoying a$$ he!!.
...Only god can judge me...
"If you don't set goals for yourself, you are
doomed to work to achieve the goals of
someone else."
Women might be able to fake orgasms but us men can fake a whole relationship.
V-TEC = Virtually-Torqueless Economic Cars
(PROG) Crew member #5
{o,o}
|)__)
O RLY?
someone else."
{o,o}
|)__)
O RLY?
Its called hydraulic lifters. They all do that and it is VERY common in all mitsu's. Im not sure about the 420a but for the 4g there is a cure thanks to the 3g big bore lifters. You can try flushing them out, cleaning them, or a couple other fixes but nothings permanent.
SUCH IS THE RULE OF HONOUR.
thats a permanent fix
I'm getting the 3g revised lifters, should run pretty quiet with some Royal Purple 10-40
