Control Arms?
Old Oct 7, 2007 | 04:50 PM
Alan's Avatar
drives euro trash
Default Control Arms?
I just ordered an 8.8 out of a 2004 Mustang....but I just noticed something I didn't see until I went to order my Steeda control arms. Apparently there is some sort of a difference with the 99-04 lower control arms. Any ideas what the differences are between the LCA's on the earlier mustangs and the 99-04's? Which ones would I need to use for this 99-04 8.8 on my Foxbody?
Old Oct 7, 2007 | 05:28 PM
topher469's Avatar
BillionClub Member BISHES
I am pretty sure the newer ones are different length. I know fox LCA's will work.
Originally Posted by DrDirt
You also make a foolhardy leap of faith in assuming that the government can execute a program properly when they can't even execute terrorists properly!!!
Old Oct 7, 2007 | 05:44 PM
$hawn's Avatar
lives in a glass house
i believe the difference is the size of the bolt that goes through the rear end...that's all
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Oct 7, 2007 | 06:40 PM
n8secstangg's Avatar
like shawn said...control arm bolts are larger on 99-04
www.racinginnovationsfl.com
www.xsrcylinderheads.com
4.842@156 and 7.53@192 on radials
Old Oct 7, 2007 | 06:44 PM
topher469's Avatar
Well I knew something was bigger!! LOL Need to stop taking these drugs and reading posts!!
Sorry for the wrong info
Old Oct 8, 2007 | 02:37 AM
Alan's Avatar
drives euro trash
Is it the bolt that connects the front of the LCA to the torque box, or the one that connects the rear of the LCA to the housing, or both?
Old Oct 8, 2007 | 03:14 AM
Default bolts
i think its just the body ones
Old Oct 8, 2007 | 05:51 AM
Duceanahalf's Avatar
is doing your girlfriend
they using 14mm diameter bolts now? the foxes used 12mm
Old Oct 8, 2007 | 06:58 AM
$hawn's Avatar
put what ever size bolt in it you want...
Old Oct 8, 2007 | 10:48 AM
Darrell's Avatar
If you are putting a 99 up rear in a fox you will need 12mm bolts for the torque boxes and 14 mm for the rearend housing. Make sure you have the correct sleeve in th LCA bushings to accomodate, Steeda sells them seperatly so you can convert arms over.
