PDA
View Full Version : tv static
eli
10-07-2007, 01:20 AM
hey guys. i have two visor tvs, for some reason the driver side tv is picking up static, the passenger side comes in perfect. anyone have this problem before or know why? i know possible reasons, because of power cords etc, is there anything i can buy to eliminate this interfence?
thanks
Notladstyle
10-07-2007, 11:31 AM
run cleaner wiring, solder the connection points, use the same ground for all the TVs.
I would check your video cable, its probably some crappy thin stuff with no shielding.
eli
10-07-2007, 04:17 PM
so u think a better video cable will do the trick
Notladstyle
10-07-2007, 08:51 PM
twisted video cable and/or a signal booster and/or better ground points
jriggs
10-08-2007, 10:11 AM
when i had headrest screens i ran into the same problem and it was a ground issue. make sure you have a real solid ground. if that doesn't work do everything notladstlye said and it'll probaly clear up
-james
