Some actual DSM Tech Questions
As some of you know I have gone and ordered the TD05H 20g ( should have been here by now..). I e-mailed TRE about porting larger wastegate(internal) and clipping. They recommended a 15 deg. clip to me. Doesnt that seem like a bit much??? I dont really know but I have hear 7 and 10 deg. so much that 15 deg. sounds crazy! Is it because the compressor wheel is so big??? Let me know guys!
Joe
94TSiAWD
http://www.cr-racing.com/talonpage.htm
Joe
94TSiAWD
hey joe i dont know about that i never heard of someone cliping the wheel 15 degrees? people told me that i chouldent of cliped mine (16g 10 ) they said that if its not cliped it would spool faster so iam not sure what the clipping dose sorry if i dident help you buthey you never know so when are ou going to get it?
Alejandro Able
1990 eclipse gsx
Alejandro Able
1990 eclipse gsx
alex galvan
13.89 @ 91mph Stock!
alex galvan
Hrmm Joe. TD05 20G...thats the smaller exh wheel. 16G-20G being the intake wheel. Smaller than the TD06 wheel. Thats why the extreme clip on the exh wheel. Same wheel as the 16GTD05. Clipping makes lag but increases top end power. Decreases surface area on the wheel...but allows more to pass through. If you are un-sure just call RREExtreme or Beernuts(Bushcur). 7-10deg is probably for the TD06 wheel. Thats my half baked opinion anyway. I would go with the 15 degree clip though. Like this
http://web.tampabay.rr.com/7seconds
13.6@108
[This message has been edited by GSTSuper16G (edited 07-19-2000).]
13.6@108
WTF anyway Joe...You have been getting a bigger trubo for like 3 months now. What the hell is going on? The DSM closet screwing you around? Sheesh
13.6@108
13.6@108
I dunno what the deal is. You would think youd need less of a clip to spin the big compressor wheel with the small turbine wheel. I guess TRE should know though.
The DSM Closet... thats funny...
My turbo better be here this week or Richard is going to get an earfull...
Joe
94TSiAWD
Joe
94TSiAWD
Anyone else interested in doing a club tuning session? After I get the diff welded (not that it will be soon) Im definitely going to want to get my car on a dyno to fine tune it...
John
90 Talon TSi AWD
2KW K4U
I heard it pulls harder at higher rpms but you suffer a little bit more at lower rpms. I guess you will need to dump it at a higher rpm at the lunch.
16gAWD
97 Talon TSI AWD
16gAWD
97 Talon TSI AWD
James
Just another unreliable fast DSM
http://www27.brinkster.com/awd16g/
James
Well Im going to trust jon @ TRE and let him do what he thinks needs to be done. I drive my car less than 2 miles to work and occationally on the weekends so I want all the HP i can generate with that 20g. If it is slow spooling Ill rev it.
John let me know when you figure out if you have an extra diff... and how much of a b!tch it is to change.
Joe
94TSiAWD
Joe
94TSiAWD
Bad news about the diff. Apparently the June 91+ builds are different from the older. Im not sure what changed but Cusco shows a different application (might be output shaft?). Im going to go ahead and weld my 90 and hope that the tranny I have in the car currently has the same setup. Hopefully Ill have a little bit better idea after I pull the old 90 tranny apart.
My current tranny is a 90 with upgraded 94 internals (94 internals using all the superceded parts) except for output shaft. Not sure how thats going to effect the swap but Ill know for sure in a couple weeks.
BTW did you ever get your turbine exhaust outlet flange from RRE so you could get the O2 eliminator built?
John
90 Talon TSi AWD
2KW K4U
John
90 Talon TSi AWD
2KW K4U
Actually John It came in UPS about five minutes ago. When can we get together for a drink or whatever so I can get that to you and/or Jeff?
Joe
94TSiAWD
Joe
94TSiAWD
