few questions. PLEASE HELP
Old Sep 22, 2007 | 05:13 PM
LShatch98's Avatar
i love making you mad <3
Default few questions. PLEASE HELP
1.my idle is jumping from 1000-2500 and when i start my car it revs to 3500-4500 for about 10 seconds and drops and starts to jump. i cant determine if it is the TPS or the IACV. 2. when i reverse it seems like my axles make a clicking noise. but only in reverse. i will give rep for help. and also my civ is LS swapped
Proven Power for all your go fast needs
Old Sep 22, 2007 | 05:16 PM
sleepinsol's Avatar
starting over
check ur iac, tps, and fast idle. u can also try n play with the idle screw on the tb. check for vaccuum leaks too. those are the most common causes of funky idle. my car does the same thing in reverse. its fine. just means that ur axels are going to be needing replacing soon, but u can still run em till they start to make clicking noises when u turn. i used to have an ls swap in my del sol (it is now ls vtec) and ran into the same problems.
Old Sep 22, 2007 | 05:23 PM
LShatch98's Avatar
were is the most common vaccum leak. i have a new intake mani gasket so i dont think it is that. and where is the fast idle?
Old Sep 22, 2007 | 05:28 PM
sleepinsol's Avatar
starting over
to find a vaccuum leak just spray some wd40 or sumthin around the intake side of the head n c where it bubbles. if it dont bubble then ur not leakin. check the throttle body gasket n c if thats leakin too. the fast idle is the thing bolted to the back of the throttle body. iac is under the intake manifold. tps is also on the throttle body.
Old Sep 22, 2007 | 05:37 PM
LShatch98's Avatar
thanks i have changed the iac with i used but clean one and it didnt help. i have another tps. but my tps is riveted on so how do i get it off.
Old Sep 22, 2007 | 09:11 PM
sleepinsol's Avatar
starting over
u can drill the riviets out if u need to....how the hell did it get riveted on?
Old Sep 23, 2007 | 10:08 AM
LShatch98's Avatar
stock tb come with riveted tps's
Old Sep 23, 2007 | 12:28 PM
rangcrx's Avatar
engine building &amp;amp;amp;best
i would not change youe Tsp sensor unless you car is stalling out when you hit the gas or come down form high rpms or your ecu is throwing a tps code..try unpluging your idel control then start the car and see if the idel is low if it is then that maybe your problem
i love AUTOZONE
Old Sep 24, 2007 | 01:01 PM
LShatch98's Avatar
^^^^that drop it to a steady 1500. so change the iac but shouldnt it be around 1000. ne other ideas?
Old Sep 24, 2007 | 05:17 PM
LShatch98's Avatar
