TpaS13
09-19-2007, 12:34 AM
Its all 07' MTX Equipment (Maybe 4 months old)
AMP:
General
Width 20.7 in
Depth 9.6 in
Height 2.5 in
Audio SystemAmplifier
signal-to-noise ratio 69 dB
Amplifier continuous power / channel qty 400 Watts x 1
Amplifier output 1-channel
Amplifier high level inputs Yes
Amplifier input signal voltage 0.1 - 10V
Crossover slope 24 dB
Crossover low pass frequencies 40 - 200 Hz
Amplifier distortion factor 0.5%
Amplifier Output Details (RMS)
400 Watt - 4 Ohm - 14.4V DC - 1channel(s), 800 Watt - 2 Ohm - 14.4V DC - 1channel(s), 1200 Watt - 1 Ohm - 14.4V DC - 1channel(s)
MTX Amplifier Dyno results.(RMS)
758 Watt - 4 Ohm - 14.4V DC - 1channel(s) X2 for Peak Power
1252 Watt - 2 Ohm - 14.4V DC - 1channel(s) X2 for Peak Power
1543 Watt - 1 Ohm - 14.4V DC - 1channel(s) X2 for Peak Power
Additional features
Cooling fan, Subsonic filter, Thermal protection, Overload protection, Input level controls
SUBS:
SINGLE 4 OHM VC---2 12s
General
Depth 8 in
Dimensions - Diameter 12.6 in
Speaker System
Speaker Type Passive
Speaker Diameter 12"
Nominal (RMS) Output Power 400 Watt
Response Bandwidth 45 - 150 Hz
Input Impedance 4 Ohm
Recommended Amplifier Power 200 - 400 Watt
Sensitivity 89.4 dB
Connectivity Technology Wired
CAP:
5 Farad, 24 Volt surge
Blue LCD Digital Meter Block Top
Volt Activated Flashing Blue LEDs
Blue Neon Accent Ring
Audible Hi/Lo Voltage Warning
(2) 4 or 0/1 Gauge Positive
(2) 4 or 0/1 Gauge Negative
+/-10% Tolerance
E.S.R. <.002m Ohm
BOX:
is an L port box....approx 2 cu ft a sub--to 35 hz
WIRING:
i can give you a 20ft piece of positive
and a 2 ft piece of negative
4 Ga.
And a remote line
Im Asking 800$ OBO trades will be accepted if you have what i want...
PM me if u have any questions
Amp: Retail 500$
Subs: Retail 250$ (Each)
Cap: Retail 240$
Wire: Retail 60$ ( or 3.00$ a ft)
Adds up to 1300$
Like i said OBO
Please no low ballers
Reason for sale-
I wanna buy a lift kit and wheels and tires for the cherokee and i want a smaller system (lol cant have 2 12s flopping around off roading)
Rob
http://i83.photobucket.com/albums/j291/Snookslayer/100_1577.jpg
http://i83.photobucket.com/albums/j291/Snookslayer/0822071710b.jpg
http://i83.photobucket.com/albums/j291/Snookslayer/0822071710a.jpg
http://i83.photobucket.com/albums/j291/Snookslayer/0822071710.jpg
http://i83.photobucket.com/albums/j291/Snookslayer/0822071709b.jpg
http://i83.photobucket.com/albums/j291/Snookslayer/0822071709a.jpg
http://i83.photobucket.com/albums/j291/Snookslayer/0822071709.jpg
AMP:
General
Width 20.7 in
Depth 9.6 in
Height 2.5 in
Additional features
SUBS:
General
Depth 8 in
Speaker System
Sensitivity 89.4 dB
CAP:
+/-10% Tolerance
E.S.R. <.002m Ohm
BOX:
WIRING:
4 Ga.
And a remote line
Amp: Retail 500$
Cap: Retail 240$
Adds up to 1300$
Like i said OBO
Reason for sale-
Rob
