PDA
View Full Version : HAY! I have J30 related questions.
bryan
09-18-2007, 06:31 PM
So, I found a few J30's at a salvage yard and I want to know exactly what parts I need to pull off in order to do a 5 lug conversion (for S13) aswell as the LSD & related parts I need with it. Any kind of tutorial..With pics would be sweet..Though, I would be happy with a parts list..That way I dont take & pay for stuff I do not need. Also, Some kind of list of tools that I will deffinately need would be great..Any help is appreciated! :crack:
mikespeed95
09-19-2007, 02:14 PM
you can get the diff and axles and thats it.
Shadytrixta1
09-19-2007, 03:26 PM
^ yes diff and axles, dont mix the sides up ones shorter.
Griffin400
09-19-2007, 04:45 PM
i believe you can use the whole rear subframe of the J30 on the S13, diff axles subframe, and the rear five lug.
mranlet
09-19-2007, 08:31 PM
Rear 5-lug is a press-in bearing rather than the bolt-in bearing - they're worthless.
Get the MAF too.
bryan
09-19-2007, 10:44 PM
Get the MAF too.
So, You mean I shouldnt get the rear axles? Just fronts?
Shadytrixta1
09-20-2007, 12:59 AM
He's talking 5 lug, you need the axles if you grab the diff.
bryan
09-20-2007, 01:22 AM
Ok, So I should just get the axles and the diff..But not the components for 5-Lug? Using the J30 diff & axles with 240 5 lug hubs? - Or can I just use the diff & axles with the stock 4 lug hubs?
Basically at this point, I just want to do LSD..Lug conversion isnt important to me right now. What do I need for that?
Shadytrixta1
09-20-2007, 09:33 AM
You want LSD grab the diff and axles. Make sure you keep all the bolts and little rubber donuts when you pull it!
doodoobrown69
09-22-2007, 01:13 PM
theyr are no front axles silly willy.
you need a huge ass socket, a 36 i think on a breaker bar(for where the axles bolt on to the hub assembly). a medium socket wrench with long ass extension with a 12 socket and two, 12mm open ends(for where axles connect to diff). and a 14 socket, and a 17 also. and then i would use the breaker bar to drain the diff cause they're heavy and u should change it anyway.
i guess you could get the MAF also, like the one guy said, for the MAF i would bring an 8, 10, Phillips, flap head and cutting pliers.
i always bring extra stuff so you don't get stuck.
o bring you a dirty towel to lay on.
SpottedMango
09-24-2007, 10:05 AM
The only way you can use the J30 in aid of your 5 lug conversion is to use the entire rear subframe. This has been done before, again, you will need the entire subframe, ebrake cables, etc.......
