PDA
View Full Version : I need help!!!! 1984 z28 camaro
camarokid84
09-03-2007, 04:28 PM
I have a 1984 z28 camaro...i found someone whos gunna rebuild the engine...but the car stopped running.? 3 people said it had 2 do with the distributor so i bought a new distributor cap ,rotor, control module, and battery...but its just turning..it wont crank!? the people who had it b 4 me ghetto riged a push start... u think that has any thing 2 do with it? any ideas? please help! thanks
Dano Moparo
09-04-2007, 10:52 AM
People usually put a push button switch in when they have trouble with the ignition switch. Why anyone would go to the trouble of wiring that instead of just replacing the switch is beyond me.
I would start with a new ignition switch, just the electrical part, you dodn't need the cylinder and keys.
GP nut
09-11-2007, 03:59 PM
i would check the coil too
TURACE24
09-14-2007, 09:27 PM
+1 by control module you mean the one in the distributor, correct? Make sure all your wires are hooked into the distributor. Those Gm distributors were awesome.. Just a power feed and its done, all self contained.. So if all the parts in the distributor are good, then you have a power feed problem. and if you have a good power feed. Then the problem may not be with the ignition.
AFTERMATH
10-10-2007, 10:53 PM
Also make sure the rotor is spining when you crank the motor over.
JonnySlick
11-01-2007, 01:35 AM
Hmm might be the fact that it is somewhat costly to repair if the car was stolen thus installment of a push was the best option.
Well anyhow on my 1992 Camaro RS 25th Ann I guess it's costly I also believe it's a real easy car to steal so I'd stay with a push if you already have it.
About the problem first thing to check like you said would be the starter and switch, from what I have heard normally thats not the case but wouldn't be suprised if it was indeed the problem.
If you push start the car does it make a click sound and just not start or does it simply do nothing? Normally a click sound would suggest the starter's solidnoid being bad.
Also like they said distributor etc... but your already onto that.
Also it's a fairly old car, I'd check the fuel pump and carb normally the car would atleast try to crank even if the 2 were bad but i'v seen cases where it does not.
Well hope this helps reply if you find out what it is, kinda interested in seeing the outcome.
Good luck!
P.S.
Make sure to check your wiring of the new distributor one wire could be the problem.
mouse
11-17-2007, 02:19 PM
frist thing is the enging truning over if yes then checkit for fire if yes then make sure you put the spark wires back on right is yes then check to make sure that it did not jump time
camarokid84
11-23-2007, 11:34 AM
the car wasnt stolen clean title i have all the keys.. I pretty much changed everything that has to do with the distributor... and its turning just not cranking someone also said it might be the fuel pump???
Na306StAnG
11-27-2007, 09:54 AM
Where are you located???
camarokid84
11-28-2007, 06:20 PM
valrico....cars @ my grandfathers in tampa
camarokid84
12-13-2007, 08:38 PM
hey im sellin it!! best offer!!! anything takes it
Blackcamaro
01-09-2008, 08:17 PM
ill take it for $100 off your lot
TURACE24
01-10-2008, 10:09 PM
he probably should have hired a mechanic....
