View Full Version : 97 nissan pickup.
fishyskawa
08-29-2007, 09:46 PM
i want to make this my project. but i dont know where to begin. anybody know anything about what it takes to make a truck slide. im not sure how to approach truck suspension or if i could even get it stiff enough ( <-- lol. grow up) to not roll over. any suggestions? is it possible to put an SR in the truck?
ImportsFTW
08-29-2007, 11:21 PM
yes it is very possible to sr the truck...you need to keep that ass end light so it doesn't hook up...as far as sliding, haven't seen it done yet, but to the sr part yes its been done successfully...g/l it would be quite the eye turner at the track to see it drifting...!!!!:)
back2Nissan
08-29-2007, 11:30 PM
Here is Rasta's truck from years ago. Not built for drifitng but i'm sure it could hold its own.
Ras's 96 SR20DET (TURBO) Truck (http://www.sromagazine.com/cars/profiles/truck/)
ImportsFTW
08-29-2007, 11:34 PM
thats one clean truck, props given
znismo
08-30-2007, 01:14 AM
The Rb and SR are supposed to be somewhat of an easy drop in... Basically different motor mounts and drive shaft and some finicking with the wiring harness..
They has been several mitsubishi mighty max trucks that had the 4g63T swap out of the 2nd gen GST eclipse and they proved good sliders as long as ur ass end is light and stays that way...
jonBODON
08-30-2007, 01:16 AM
there was a nissan truck in PA it was boosted, and it killed it. not sure where to find info on it.
back2Nissan
08-30-2007, 01:21 AM
here is a link to a Mits truck. Nice vids!
DrifTruck home (http://www.thedrifttruck.com/)
doodoobrown69
08-30-2007, 08:03 AM
whaaaaaaaat
fishyskawa
08-30-2007, 08:46 AM
awesome. thanks for the support. now i just have to figure out suspension first.
sponsored
08-31-2007, 10:19 AM
get realy wide spacers for one , and might want to consider cutting off the top.
IThaJokaI
09-01-2007, 10:44 PM
there has been both a rb25det powered nissan truck and a rb26dett powered datsun truck. both were drift trucks and there was a 99 nissan with a ca18det and an early 90s nissan with a sr20det, built for drift/drag. So it can be done. If your truck has a ka24de It would be VERY easy to swap a CA or SR into it.
-Mike
VEX MOOCH
09-04-2007, 06:38 PM
Buddy just get a frikkin 240 already lol
4wheeldriftS13
09-20-2007, 03:28 PM
SR swap truck = Rasta-mobile
Thats BRian's (Rasta) old truck..rip.
he is a cool guy and probably could help this guy out. PM him if your about doing an SR swap.
mranlet
10-16-2007, 12:42 AM
SR swaps in hardbodies are a PITA, a 97 might not be so bad.
Stock final drive ratio of a truck will feel like plenty of power once decent-sized wheels and tires are mouted. 2 main issues with drifting trucks are the lack of weight over the rear wheels and the flimsyness of the 2-channel frame. Moving the fuel tank as far back as possible will help a little on the weight balance side, and adding some serious stiffening to the stock frame will help the torsional rigidity (and I mean more than just a rollcage).
KAILUAZ
11-01-2007, 11:43 AM
Sick truck!
Jdm SiCkness
11-01-2007, 12:05 PM
built kA-t truck .. werd
RB240Mike
11-04-2007, 09:07 AM
My buddy wants to build a nissan hard body race/ drift/ show truck lmao we'll see about that one.
streetcivic93
11-04-2007, 06:59 PM
im sure with enough effort you could retro fix/fab in a s13 or s14 sub frame? that would delete the solid axle and allow the multilink rear end? then coilovers could be utilized. as for stiffening the truck, could a baja style setup help? its like a roll bar only its tied into the very rear of the truck by the tailgate and then a huge X bar gives it rigidity. then put the volk Te truck setup on it and slam that shit. theres plenty of lowering spindles to help lower the front with correct geometery. GOOD LUCK!!!
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
