f/s perfect power stand alone piggy back comp.
as soon as walt (realspeed) gets the car done sometime next week this will be for sale here is what it is and it also comes with a 2.5 bar map sensor.
MAKE OFFER FOR IT.
and come with software!
here is the link with all info you need on unit! i bought it local in new port richey.
www.locustom.com, supplyer of custom antennas and EMS systems
SMT 6
Smart Tuner
ADDS TUNING CAPABILITY TO ALL ENGINES
TUNE ONLINE VIA YOUR PC, NO RE-CHIPPING NEEDED
TUNE WHILE YOU DRIVE
MONITOR & TUNE AFR (Lambda)
FULL DATA LOGGING OF INPUTS
TUNE YOUR ENGINE THE SMART WAY
TWO SEPARATE TUNING MAPS STORED IN MEMORY
SMT6 used as fuel injection
SMT6 used as ignition
SMT6 wired to a Megasquirt
SMT6 to convert to speed density
SMT Basic features
Want to learn more?
Get the same info the pros use
(SMT install guide) (SMT software manual) (SMT tech notes)
standard SMT6i
$389.41 Shipped
This is the sensor that ships with the PRS units.
Reads up to 22.5psi of boost
(use for N/A and boosted motors up to 20psi, if you boost above 20psi you should consider the 4 BAR sensor for accurate fueling in the event of over boost)
$80.00 Shipped
(interchangeable with the Perfect Power 2.5 BAR MAP sensor)
MAKE OFFER FOR IT.
SMT 6
Smart Tuner
SMT Basic features
Want to learn more?
standard SMT6i
$389.41 Shipped
$80.00 Shipped
Basic injector/solenoid control wiring of the SMT6.
This allows batch fire of 1 to 6 high impedance injectors (can run low imp inj but the total output is current limited to 7 amps, yes it is possible to make a fly back board to handle greater loads) If NOX INJECT software option is turned ON (global settings, system config) it pulses wire 21 at 38Hz allowing connection of relays to control solenoids for NOS or alternate fuels. This can also be used for boost modulator solenoids.
bump the 2.5 bar map has been sold ! it is only computer and software.
make offer
make offer
