View Full Version : 20w50 synthetic on a boosted car??
Jason.
08-16-2007, 02:45 PM
Will it hurt? I've heard from lots not to run thick oil in a boosted car, I'm running 10w30 synthetic now, just was wondering if 20w50 is too much for a boosted b20?
Sneakin Deacon
08-16-2007, 03:21 PM
depends on how tight your clearances are...i always run a 10-30 or a straight 20w...but it rarely ever gets that cold around here that your oil would drop to a 10 weight...i personally dont see any reason to run a 50 weight unless its a really worn out motor.
matraca112
08-21-2007, 10:25 PM
Some say it will leak on a turbo. But I have worked on cars and the only way it is going to leak is if you have a leak. But a 10-30 is going to be the best for you.
manifoldmike
08-22-2007, 07:56 PM
20 50 is a little heavy for a street car. only downside is that you have to let the car get to operating temp before you drive it. you can potentially do some damage if you don't.
i would also check the service manual to make sure your pump can handle it.
the weight isn't as much of a problem down here in the south, but if you plan on taking it anywhere remotly cold, i would think about sticking with a 30w.
eksilver1
08-25-2007, 10:41 PM
have the same set up i used 20 50 all the time and runs great no problems good luck
busa4
09-01-2007, 08:10 PM
20w-50 is fine in warm climates. you definetly dont want to use it if it gets below freezing.
Content Relevant URLs by
vBSEO 3.2.0 RC5
