Swap info PLZ look
Old Aug 12, 2007 | 11:14 PM
Toby1526's Avatar
Default Swap info PLZ look
hey guys i blew my motor today( block cracked and busted ) and i need to get a swap i had a p28 obd2 Mini me swap in it. Now my question is what all will i need for a different motor? diff ecu? diff wiring harness? etc.... i am really not to keen on this subject so if u could and if u know plz tell me what exactly i need to get for the swap to work in another words explain it to me as if i were a child lol wel u know what i mean. any info would be helpful thanks guys.
Old Aug 13, 2007 | 07:00 AM
Toby1526's Avatar
Old Aug 13, 2007 | 07:21 AM
rangcrx's Avatar
engine building &best
just fine a d16z6 long block complete
i love AUTOZONE
Old Aug 13, 2007 | 09:30 AM
FC_V8's Avatar
^+1
Old Aug 13, 2007 | 01:53 PM
dippincrx's Avatar
save the s.o.h.c
+2 or find a good block and swap over the ehad if it is good
Old Aug 14, 2007 | 10:56 PM
two ways to go:
Put a "stock and running" engine in it with the same block, so you can drive until you get time to pull your current head and put it on
the same kind of block that you had.....then everything
will be back to where it was.....Advantage, gets you back on the road now while you build something. Requires that you buy: 1.a running engine for now, and 2.a block to put your head onto while you can have use of the car..
OR
If you have time, build something now. Take the head off your busted block and put it on a good block, and put that back in the car......disadvantage, the car cannot be used immediately as if you
had taken option 1 above.
Advantage, you don't have to buy a "stock and running" engine.-Bob
