PDA
View Full Version : fuel pump problem...
scoobaru05
08-11-2007, 05:17 AM
Start with the mods i have a VF39 deatschwerks 565 cobb spec injecors and STI TMIC with the cobb VF39 map...Alright well i put a walbro 255 in yesterday because i plan to get protuned here in the next couple of days and when i started the car up the CEL came on gave me a code (P0183) but turned the car back off, then turned it back on and the code went away...so i thought no worries...well i went for a little test run to see if everything was cool and seemed ok then i got on it and thats when i started to feel the car start to hesitate especially when i started to reach higher RPMs.
So i was wondering if it was because of the base map thats on the car and just need a protune or could something have gone wrong during the installation (which is more than likely it)...so if anyone could help me that would be great
P0183 Fuel Temp Sensor A Circuit High Input
Thanks
SnowMann
08-11-2007, 12:15 PM
It would help to know what the code was...
Did you do any logs? Very possible that the hesitation you felt was det...tread lightly until you get it figured out.
flystiguy01
08-11-2007, 12:58 PM
fuel pump install is a pretty straightforward deal... its almost plug n play so i dont think that would be it...
one way to check it would be to pull the fuel pump up outta the trunk a few inches and turn your key to the on position and look for leaks.. just dont have a cigarette in your mouth. :)
ryan_west06
08-11-2007, 02:22 PM
ya it would really help if you had the code number! my walbro pump install was simple and easy!!! no problems here.....
wonder what it could be..... i dont think you have to prime the pump.... since the pump is empty id say let the car run some gas thru the pump.... you might have some air bubbles in the line, im guessing!
SnowMann
08-11-2007, 09:12 PM
did you change the name of this thread?
fat angel
08-11-2007, 10:27 PM
if you got the cel with the pump you might want to pull the code. more than likely it's the seal around the lid to the pump. the tank gets pressurized and the system can tell. you'd get the same cel if your gas cap wasn't on all the way.
go to autozone or advanced and as to use their obd scanner.
scoobaru05
08-12-2007, 03:28 AM
No i didnt change the name...i do remember the code though it was P0183 Fuel Temperature Sensor A Circuit High Input
No i didnt get it logged i haven't had time to go get it done
fat angel
08-12-2007, 10:52 AM
hmm... have you tried resetting the car by taking the negative on the battery off? if that doesn't do it, you might want to pull it back apart and make sure everything is still ok.
