Intermittent fuel pressure
I performed a 255lph fuel pump transplant on my 1990 GT. I have done this operation once before on this same car (with a stock replacement pump) as well as once on my old Aerostar with good results. However this time I have a problem I am hoping someone with be able to help me with. After replacing the pump, my fuel pressure gauge showed slightly more fuel pressure (from 40 to 43 psi), so I adjusted the Kirban regulator. At first the fuel pressure dropped as expected, then the gauge needle jumped and began fluctuating between 44 and 50 psi with no adjustability. This condition caused a high idle (1000 vs 750 rpm). I checked the fuel return line for kinks and found none. The next day, the regulator worked perfectly and I was able to set the fuel pressure. I took my car out for a spin and when I returned, the fuel pressure again was erratic and the idle higher than normal. That is my problem. I hope someone can throw me a bone. Thanks in advance.
1990 Mustang GT, Holley Systemax, GT40X, B-cam, 24lbs injectors, Pro-M 80mm, 70mm PP TB, BBK LT w/X-pipe, Magnaflow catbacks, Baer, Eibach, Tokico, Walbro 255lph, UPR subs/uppers/lowers, 31 spline Mosers
with the kirban you can just run it static. plug the regulator line if you still have it.
SUCH IS THE RULE OF HONOUR.
Thank you for your answers. The vacuum line is good. I think I'll pop the stock regulator back on and see what it does.
I think what he is saying is, leave the vacum line off and see how it reacts
Yea i would try that sounds like the regulator didn't like the new pump for some reason.
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
Thanks for your answer. I do have a gauge and the fuel line keeps pressure. My car runs well but a little rich running the Kirban statically (without vacuum). I performed a vacuum check on the regulator today and it bleeds down completely in about 1 to 1-1/2 minutes, so I am assuming the diaphram is gone.
Might not be regulator, hows the o-ring where it attaches to the rail?
Have you put a noid light on iinjectors to see if you have on that might
be outta whack?
I chased this problem on my GN ended up sending injectors out to be cleaned and flowed. This was after 2 new fuel pumps, had a newer Kirban but car sat so I bought new Accufab reg.
Had trash in a couple of them, wasnt letting them seat internally.
be outta whack?
Fuel injection FTL
Largo fl 33773
MV#72427
Largo fl 33773
MV#72427
