Dorsey233
07-23-2007, 03:47 PM
I have 2 12" Flame Excurrision audiobahn Subwoofers for sale along with a 1200 Watt sony Xplod 2 channell amp and Box..Box has dual recieving ports for the amp so you can run 600 watts individually to each speaker here are the specs on the Subs..Very Nice Set up im only ask 350 or obo an i am accepting trades. Looking for a ps3 or Xbox360 or an in-dash touchscreen headunit. You can reach me at 352-442-4801 and ask for Mike....
http://www.audiobahn.com/Audiobahn06/images/products/woofers/AW101T.jpgFLAME EXCURSION SERIES
For a cast basket design, this subwoofer is relatively shallow. The 12-inch model measures in at merely 5 5/8 inches in depth, giving you the ability to mount this subwoofer in tighter installation environments.
SURROUND
The 2” PHAT foam surround is made from a combination of two different materials. The base material is soft and flexible. It is coated by denser, more rigid foam. This union is versatile because it gives the surround a flexible yet durable structure that will hold its shape over time.
TINSEL LEADS
To prevent tinsel lead rupture, Audiobahn uses woven tinsel leads in its entire line of subwoofers. The tinsel leads are hand-woven into the subwoofer’s spider, ensuring the wires do not wander from their intended position or fracture during extreme operation.
COMMON FEATURES
PHAT 2” Foam Surround
Non-Pressed, Non-Transfer Paper Cone
KM3’ Coated for Virtually No Cone Distortion
Single 4 Ohm VOICE COIL
Multi-connect Lug Lock Terminals
http://www.audiobahn.com/Audiobahn06/images/products/woofers/flameexcursionspecs07.jpg
SURROUND
TINSEL LEADS
COMMON FEATURES
