View Full Version : Question about dual battery setup w/ diff. batteries
Kramer2.0SPI
07-20-2007, 07:43 PM
Hey I currently have a Stinger SPV35 under my hood and I would like to have a dual battery setup with the stinger in my trunk and a thin buddyclub battery under my hood (to make room for the charge piping i'm constructing for my turbo setup) with a dual battery isolator and a 180amp alt.
my question is, is there any problem with running two totally different batteries in a dual battery setup?
rep will be given to helpful responses, thanks
Nope, as long as you have a pretty decently sized relay to separate the two batteries when not in use, otherwise since they are both different batteries, they will drain each other out leaving you stranded somewhere.
Google Stinger 80amp or 200amp relays, they work well.
I used a 200amp relay to separate my main battery from my optima yellowtop and it always worked like a charm and easy as hell to hook up.
d.a_user
07-20-2007, 08:16 PM
yea the brands shouldnt matter at all
Kramer2.0SPI
07-20-2007, 10:25 PM
thanks, i'll check into that
TJElite
07-21-2007, 12:27 PM
you said you have an isolator. If so, you don't need a relay. There are pluses and minuses to either, but they both work.
Toby
:doh: didn't see he said isolator in his main post. =[
Content Relevant URLs by
vBSEO 3.2.0 RC5
